Which other car wheels fit 89 2wd pickup?
So I've tried searching the forum and it has been increasingly difficult to find much information regarding the 2wd 5-spoke model. I recently purchased the Toyota truck for a deal i could not let down. The main use is going out to the mojave for camping trips. That said i am looking to lift it to give it some ground clearance (larger wheels would probably be fine) and perhaps a body lift to add cosmetics. I am looking to change out the wheels on the cheap so i am wondering if there are any other car models out there that have a similar pattern as the 5-spoke 2wd 89' yota? The 03' F150 looked similar but i'm not sure... I'm sure many of you have dealt with the same problem and so i am looking for advise. Thank you
Nice, i was also curious to see what it would look like. Anyone out there have the 2wd model with just larger tires? I believe my vehicle right now has 14'' rims and small tires. I'm really not into that lowrider look.
The 15s I have on my 84 2wd fit both my sister current Jeep XJ and former Jeep KJ and they are both 5 spoke.
As for pictures of 2wd trucks with bigger tires here is my 84 with 30x9.5x15s on the rear and 215/75R15s on the front with cheap steel wheels.
So I've tried searching the forum and it has been increasingly difficult to find much information regarding the 2wd 5-spoke model. I recently purchased the Toyota truck for a deal i could not let down. The main use is going out to the mojave for camping trips. That said i am 30000k hid kit to lift it to give it some ground clearance (larger wheels would probably be fine) and perhaps a body lift to add cosmetics. I am looking to change out the wheels on the cheap so i am wondering if there are any other car models out there that have a similar pattern as the 5-spoke 2wd 89' yota? The 03' F150 looked similar but i'm not sure... I'm sure many of you have dealt with the same problem and so i am looking for advise. Thank you
aciorba23
Jun 29, 2015 04:18 PM
infinityisfive
Jun 16, 2015 06:51 PM
AUJWE
7
Jul 11, 2002 09:46 AM
