newbee t100 4x4 tire question help???
nice site,,,maybe someone knows the answer? I bought a super clean garaged kept 1997 t100 4x4,,,The original owner I spoke to and asked 1000 questions to was the only owner and driver of this truck it is a sr5 extended cab 4x4 auto with 3.4 and a.c .my truck has a factory decal in drivers door that tells about tire inflation on a 15 inch wheel,,????my truck has 16 inch factory wheels,,,I wanted to go with 31x10.5 tire but cant find them in 16 inch,,I am leaving it stock height putting pro comp 9000 shocks all around a pro comp stabilizer,,truck sits nice and high no sag ,I really lucked out with this find,thanks in advance for any
,WHAT IS BIGGEST TIRE i CAN USE WITHOUT ANY RUBBING???
hey go to 4wheelparts.com
http://www.4wheelparts.com/aux_incl/tire_fitment.html
go to tires and then you find the tire fittment guide. basically you you can put up to
33's on it and it should be okay?
im running 31's and im happy though.
i have the same truck you do just not and sr5 sits nice and high stock i think. im content and its great off road how it is. might get a body lift someday. not much suspension stuff out there
https://www.yotatech.com/forums/f132...-stock-188250/
look at this convo though. should help more than i can
t100 tire help
Thanks for the help...to my dismay the frame was cracked on the t100,I was putting pro comp shocks all around,,while under truck next to the gas tank I saw a crack,,,turns out the frame was rotted and I was able to get my money back ! I fell in love with the t100,,,I am looking for a 1997-1998 4x4 t100 xtra cab ,auto with a/c and they are sure hard to find,,,thanks
Sep 4, 2015 09:27 AM
