93-98 T100s All T100 trucks
Can i run 33's on t100 stock
Old Aug 5, 2009 | 10:10 AM
fitzman62's Avatar
i currently have 31/10.5/15 but thay look small so i want to go bigger
1997 t100
flowmaster muffler custom exhaust
4runner rims
rakcho rs5000 shock
Old Aug 5, 2009 | 10:20 AM
Lumpy's Avatar
Should be able to, might have a bit of rub. I'm running 33X12.5 on a stock 4runner and after it ripped part of the rear bumper off it no longer rubs.
It was hit at some point and was pushed in some. I had to remove the front mud flaps as well, they were rubbing.
Old Aug 5, 2009 | 10:23 AM
fitzman62's Avatar
yea i was thinking that the backs will fit fine and the front might rub but if so maybe i will do a little cutting
Old Aug 5, 2009 | 10:30 AM
Lumpy's Avatar
Try it out and if it rubs too much lift or cut...but I think you'll be alright.
Old Aug 5, 2009 | 12:18 PM
hotshoe's Avatar
Pull out all the plastic liners and pound the seam flat on the firewall/fenderwell. They will fit
Old Aug 6, 2009 | 07:27 AM
topdown4runner's Avatar
From: Somewhere between Disney World & Daytona Beach
I am running 32's on stock rims, no lift.
I get a wee bit of rub at full lock. 33's should rub more...put in a body lift! They are only about a hundred bucks or so.
Old Aug 6, 2009 | 04:19 PM
fitzman62's Avatar
i might do a three inch body lift and run 35"s
Old Aug 6, 2009 | 04:34 PM
86Toyrunna's Avatar
38s.. no lift.. cut the livin daylights out of it lol
Old Aug 7, 2009 | 07:44 AM
fitzman62's Avatar
thats also a possibility i think i am going to just do some cuting
Old Aug 9, 2009 | 04:57 AM
becaron's Avatar
balljoint spacers in the front might help some
Old Aug 9, 2009 | 09:20 AM
Bagger's Avatar
I ran 285/75/16's, equal to a 33x12.50x15 (more or less) for years with only a slight rubbing with the wheel turned at full lock. No cutting or hammering the pinch weld and no issues.
I've since added 1" ball joint spacers and eliminated that rub. I also moved up to a 255/85/16, equal to a 33x10.50x16 (more or less) with only the spacers and still no rubbing.
Old Aug 9, 2009 | 05:06 PM
Lumpy's Avatar
Well we went for a bit of trail runs yesterday and I only had some rubbing on the pritties on the rear. Bumper and some molding. Ripped the molding off and I'm going to remover the side bumper this week. My rear coil are shot on the runner, so keep that in mind.
Old Aug 10, 2009 | 05:32 PM
BamZipPow's Avatar
Someone might buy those trim pieces off of you...here...
Old Aug 10, 2009 | 06:06 PM
Lumpy's Avatar
Well If I can get the rest off without destroying them I'll post them up. I had to make trail modifications so they were not in the best of shape.
Old Aug 11, 2009 | 07:16 AM
t-1hundred's Avatar
yes you can run 33's with a stock lift but you will have to sacrifice the front mud flaps (if you still have them) and jacking up the torsions a wee bit
Old Aug 11, 2009 | 07:18 AM
t-1hundred's Avatar
....no cutting is required either!
Old Aug 12, 2009 | 08:53 AM
fitzman62's Avatar
thanx for the help
Old Aug 18, 2009 | 09:08 AM
fitzman62's Avatar
about to get started with this whole project , hotshoe says to pull out all the plastic do you literally mean pull it all out even the platic towards the front of the wheel well
Old Aug 25, 2009 | 06:27 PM
hotshoe's Avatar
Nope- just the stuff in the fenderwell near the firewall.
kazuya2416
Apr 5, 2024 02:17 AM
Jun 1, 2021 01:51 PM
Doug4320
Mar 24, 2018 10:11 PM
lledwod
Aug 30, 2016 01:03 PM
garagespace
Jul 9, 2015 08:37 AM
