Need help choosing tire size please
Old Nov 28, 2009 | 11:18 AM
utjoe09z's Avatar
So I just ordered Toytech lift for my 96 4x4 Tacoma. Everything is basically stock. after installing my lift i will be looking for tires. any advise on what size to get? he is the lift i ordered,
http://www.toyteclifts.com/index.php...mart&Itemid=72
Kinda new at this any help will be appreciated =)
thanks,
-Joe
Old Nov 28, 2009 | 01:01 PM
4Crawler's Avatar
You'll find some general tire size vs. lift information for the Tacoma below:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old Nov 29, 2009 | 01:20 AM
utjoe09z's Avatar
perfect thanks man =)
Old Dec 1, 2009 | 08:03 AM
1st_gen_runner's Avatar
How much total lift? Cause if you tell me that I can give you a tire size. I work at a tire store so I know what works and what doesn't.
Old Dec 1, 2009 | 06:52 PM
utjoe09z's Avatar
oh cool, yeah the front is a 3" and the rear is a 2". The tire chart that 4crawler showed me said that the front would fit a 33x9.50, but im not to sure if this size will fit on the back.
Old Dec 1, 2009 | 08:16 PM
4Crawler's Avatar
Usually if a tire fits up front, it'll fit in the back just as well. Why? Front tires move up and down with the suspension, but they also have this nasty habit of turning side to side as you steer. And since the tire sits outboard of the steering knuckle pivot point, it sweeps out an arc while turning side-side. So you need more room to fit that sort of tire inside the wheel well that the rear tires that just move up and down only.
Old Dec 2, 2009 | 03:47 PM
yotaman101's Avatar
A tire that many people people run with those type of lifts is 265/75/16, this tire fills out the wheel-well fairly well. If you want an even better tire with that lift you can squeeze in 285/75/16 (roughly 33's). Im running these on my truck, and only have slight rubbing at full lock.
Old Dec 3, 2009 | 01:06 PM
utjoe09z's Avatar
Okay cool, so if i have the 15" stock alloy wheels the only thing that would change on the tire size would be the 16 to a 15 correct?
Old Dec 3, 2009 | 04:49 PM
yotaman101's Avatar
oh, since you have 15" wheels you will not be able to run the 285 tire becuase it is not available for the 15" rim. The 265/75/15 tire is available but you won't have to much to choose from. So you best option would either be a 32x11.50R15 tire (which is 11.5 inches wide and 32 inches tall) or a 33x11.50R15
Old Dec 5, 2009 | 09:15 AM
utjoe09z's Avatar
alright then, thanks for all the help!
Old Dec 5, 2009 | 01:51 PM
yotaman101's Avatar
yep...not a problem
Old Dec 5, 2009 | 02:00 PM
93yotaSR5's Avatar
you could even go with a 33x10.5x15 i think only bfg and super swampers come in this size.
djpg2000
Nov 11, 2020 04:56 AM
jgallo1
Oct 26, 2015 06:39 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
