if i put 33s on with my stock 4:10 gears is it going to ruin somthing?
Old May 29, 2009 | 06:15 PM
darbtaco11's Avatar
i have a 99 taco and was wondering if i put 33s on with my stock 4:10 gears is it going to ruin somthing ? will it mess somthing up in a short amount of time? what could happen? will i be fine? its a v6 3.4L
Old May 29, 2009 | 06:21 PM
DeathCougar's Avatar
Your truck will explode into hellish ball of fire. DO NOT PUT LARGER TIRES ON IT!!!
Old May 29, 2009 | 06:35 PM
darbtaco11's Avatar
well i know ur not being serious but what exactly are you trying to say
georgiayota's Avatar
your truck will be good, just less power
Old May 29, 2009 | 06:38 PM
darbtaco11's Avatar
well am i gonna fry somthing in a couple of months or not at all?
Old May 29, 2009 | 06:39 PM
darbtaco11's Avatar
and how much less power
Old May 29, 2009 | 06:57 PM
Justinlhc's Avatar
Some people say they can't notice the small amount of power loss, some people say they did notice. It's not that big of a jump. You might find yourself having to use 4th going up hills on the highway, but you've got 190hp so it shouldn't be that big of a deal. I'd at least plan on changing gears sometime in the future, but you will be perfectly fine to drive like that.
Old May 29, 2009 | 07:07 PM
hodgepodge79's Avatar
your truck will be fine. it doesn't know/care if you are driving on 25" tires, 33" tires, 35" tires, etc. (as long as all 4 are pretty much the same size). Your speedometer will be off but that's all.
Old May 29, 2009 | 07:09 PM
Tacoclimber's Avatar
REAL WORLD EXPERIENCE:
I have a 2003 Tacoma 4wd DC with auto tranny and 4.10's.
I am running 285/75R16's (33's, for all intents and purposes). I have been for well over 2 years.
With the exception of needing to use the OD button more often on long distance trips up hills, and a slight drop in gas mileage, I have experienced NO problems. I could even chalk up the drop in mileage to the fact that I am running steel rims which are heavier than aluminum.
...Unless you consider the ability to crawl over obstacles that I wasn't able to crawl over with 31's a drawback. In that case then, yeah.
Old May 29, 2009 | 07:17 PM
darbtaco11's Avatar
thanks yall
Old May 29, 2009 | 07:21 PM
4wdfanatic's Avatar
Hi everyone, I have recently swapped from the evil world of Jeep (2004 Rubicon) to become a proud owner of a 2009 Tacoma Double Cab 4x4. It is time for the mods to start and I was wondering if anyone knew what the largest size tire is that you can fit on the stock truck? The truck will be used for overlanding, not rockcrawling. Thanks.
Old May 29, 2009 | 07:37 PM
darbtaco11's Avatar
i have 31 10.5 on when i had my truck stock im thinking 32 to be safe but 33s might be pushin it
Old May 29, 2009 | 09:22 PM
TOYOTA 1's Avatar
I'm runnin 33's with the 2.7 and 3:90 gears, been runnin it that way for 2+yrs with no problems.
Old May 29, 2009 | 11:04 PM
scuba's Avatar
Hit up TTORA, Link in my sig line, They have MANY 05+ tacos and it is a good knowledge base and you will find all the info you need before you have to ask.
Good luck
Old May 30, 2009 | 01:44 AM
dropzone's Avatar
Fossilized
not too much of an issue, I am running 35's on my '81 with a 22R, I have issues with power
hills suck now....
265/70 (75) stock. I did a spacer lift (sucked) on my '05 and ran 285/75/16's on my '05
Old May 30, 2009 | 05:22 AM
4wdfanatic's Avatar
Thanks guys. I am more and more impressed with the truck. By the way, nice truck ocdropzone. Are you happy with the ARB bumper? I have had two and that is going to be the next purchase after tires.
Old Jun 5, 2009 | 05:45 PM
darbtaco11's Avatar
sick bumper
Old Jun 5, 2009 | 06:45 PM
Team420's Avatar
Idk about the taco... but I got 33's on my 91 3.0 with 4.10's , and I honestly dont notice too much difference.... only on steep hills do I have to downshift, and I actually get better mpg's on the highway from the lower revs...
bigjstang
Jun 2, 2025 03:56 PM
lledwod
Aug 30, 2016 01:03 PM
Jnkml
Jul 6, 2015 01:20 PM
