Extended wheel studs???
Old Feb 5, 2010 | 06:47 AM
nbeales's Avatar
Unhappy Extended wheel studs???
I have a 85 4Runner and installed a set of ION 171 wheels (15x8)... These are alloy wheels and require a taper on the lug nuts used. I purchased a set of tapered lug nuts (assuming that would be all I needed) but because of the thickness of the wheel centers there is certainly not enough thread engagement between the studs and nuts.
I have found that they are 12mm x 1.5 but have not found anyone to advertise an extended length stud specifically for toyota trucks. The two large auto parts stores don't have them and can only tell me what the stock replacement would be (don't have those either). I'm concerned that those found on ARPs site will not have the proper shoulder...
Can anyone help?
Old Feb 5, 2010 | 06:53 AM
mastacox's Avatar
A good auto parts store should be able to help you find longer studs by comparing the stock replacements to the rack of studs they have. Just look at the studs side-by-side and as long as the splined section is the same diamter and length you're good to go.
Old Feb 5, 2010 | 06:55 AM
waskillywabbit's Avatar
Tapered lug nut with shank.
Old Feb 5, 2010 | 07:33 AM
nbeales's Avatar
Do different shank lengths/diameters exist? I'm not sure how much space exists between the outer diameter of the studs and the inner diameter of the holes. This is one item that I don't have a lot of experience with so please forgive my ignorance.
Old Feb 5, 2010 | 08:33 AM
4Crawler's Avatar
I have run Dorman wheel studs for many hears on my '85. 610-144 (2-7/8" long - 3/4" longer than front studs) and 610-073 (2-3/8" long - 3/4" longer than rear studs). They are 1/2x20 thread but the lug nuts use the same size socket as the Toyota lug nuts and they press into the wheels hubs lust like stock.
Old Feb 5, 2010 | 09:55 AM
HazMat's Avatar
http://www.hunt4steve.com/05TacoExtLn.html
Read this.
Old Feb 12, 2010 | 08:29 AM
nbeales's Avatar
Thanks 4Crawler and HazMat! Does it seem logical that a wheel such as the ION would be set up to take nuts with a shank? I think I'd rather just replace the studs as I am replacing my birfields, and inners/rear axle shafts as soon as my packages arrive.
The matrix studs may work for me but...
Type: Serrated Stud
Thread: M12-1.5
Knurl Dia.: 14.33mm
Length: 52.5mm
Shoulder Length: 25mm
UP FRONT
Type: Serrated Stud
Thread: M12-1.5
Knurl Dia.: 14.17mm
Length: 44.5mm
Shoulder Length: 12.5mm
OUT BACK
I really don't want to spend ARP $ ya know?
I understand that 10ths of a mm aren't a lot but this is for a fairly significant part of the vehicle.
young buck
18
Aug 27, 2018 02:40 PM
accuracy
Aug 6, 2015 12:32 PM
upongame619
Aug 1, 2015 12:12 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
ksmudrunner99
Jul 21, 2015 05:33 AM
