Can/ will new(er) Toyota wheels fit 1st gen pickup w/ locking hubs?
Old Dec 19, 2010 | 06:51 AM
HMH's Avatar
HMH
I'm in the early stages of a DD build project on an '84 longbed I recently picked up, and the BFG 33's that came with the truck have lots of tread left, but are showing a bit of dryrot cracking in the sidewall. They are fine for now, but replacement is on the radar. The tires are currently mounted on the typical AR 15x8 rock crawlers, but I've been thinking about possibly "upgrading" to new OE toyota wheels to freshen it up a bit. I'm planning on running 32's with a new OME lift so I'm looking for Tundra, Landcruiser, Sequoia, etc. for the extra width.
My question is, with new trucks having auto hubs, will new model wheels fit over the manual locking hubs on older trucks? If so, is it as simple as running the fronts with the center caps removed?
Any and all advise it appreciated. Thanks folks.
Old Dec 19, 2010 | 08:21 AM
Nimyad's Avatar
I don't know if they'll fit or not but i know thr backspacing is different, you might have to run some big a$$ spacers up front but not positive
Old Dec 20, 2010 | 07:14 AM
HMH's Avatar
HMH
Thanks for the heads-up, I didn't think about the BS, I just assumed they were the same. I'll look into that.
Does anyone happen to know if any newer model Toyota rims match the BS of 1st gen SFA?
Thanks again.
Old Dec 20, 2010 | 07:32 AM
waskillywabbit's Avatar
IFS rims will NOT fit SFA without wheel spacers.
:wabbit2:
Old Dec 22, 2010 | 06:26 AM
HMH's Avatar
HMH
Thanks Nimyad, Wabbit,
This is a project truck, so no need to cut corners w/ spacers. I'm looking to make this long(ish) distance highway friendly so I'm probably going to step down a tire size to 32's anyway - might as well replace the whole package.
What is the generally approved backspacing for a solid axle w/ 32's-33's? Searching is turning up 3.75. The truck has bushwacker cut-outs that I'll probably leave on there, so a slightly wider stance wouldn't hurt. I'm also planning on stepping up to FJ80 rotors w/ V6 calipers if that makes a difference.
Thanks.
Old Dec 22, 2010 | 06:34 AM
Yep. 3.75
:wabbit2:
Old Dec 22, 2010 | 06:38 AM
dropzone's Avatar
Fossilized
Also your truck is not a first gen, those are 79-83. Your truck is a considered a 2nd gen 84-88, just that 2nd gen 84 & 85's had the SFA
Old Dec 22, 2010 | 07:35 AM
HMH's Avatar
HMH
Thanks Wabbit, it's always good to confirm specs before pulling the trigger.
You're right Robb, sorry about that. I always lump together 1st gen runner/ 2nd gen pickup - didn't mean to leave the OG guys out!
Old Dec 22, 2010 | 07:17 PM
4Crawler's Avatar
Yep, 3.75" or less backspacing on the solid axle trucks, due to front wheel and steering arm clearance:
- http://www.4crawler.com/4x4/4R_TechI...l#Wheels/Tires
Less backspacing = wider stance:
- http://www.4crawler.com/Diesel/Tires...ningTrackWidth
ladybugRC
458
Aug 21, 2020 10:41 AM
justdifferentials
14
Jun 11, 2017 08:36 PM
G-off
Dec 29, 2015 12:44 PM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
