1983 4x4 cost of regearing to run 33” tires on 15x7 stock rims?
Old Aug 17, 2018 | 10:53 AM
joesgarage's Avatar
1983 4x4 cost of regearing to run 33” tires on 15x7 stock rims? Any input, thanks...
Old Aug 17, 2018 | 12:47 PM
millball's Avatar
Can you do any of the work yourself??? Just the purchase of gears and bearings would be $600+ Adding any kind of lockers would run parts costs way up.
What you got now??
Old Aug 17, 2018 | 05:19 PM
dropzone's Avatar
Fossilized
pull the 3rd's yourself and you save about $1k
check out Zuk's site gearinstalls.com
plan on $300 per diff plus a master install kit and gears for each one 4.88's
Old Aug 19, 2018 | 05:50 AM
joesgarage's Avatar
What you got now??
just all stock parts on my truck. Have a new motor from jasper motors and a rebuilt transmission. I’ve been getting some crazy quotes from different shops, pretty expensive. One quote was about $1500 per axle?!?!
Old Aug 19, 2018 | 08:41 AM
dropzone's Avatar
Fossilized
you can pull the rear 3rd easily in 45 minutes to an hour.
front is a little more work.
hence why i suggest you pull them and take them in.
PM Zuk...with parts and shipping you are probably looking at $1500 if you pull them yourself...and it's a good time to go through your front end anyway
Old Aug 19, 2018 | 08:42 AM
Co_94_PU's Avatar
What you got now??
Parts:
600+ install kit
Gear setup labor:
300+
R&R labor:
1500 minus 900 for parts, leaves 600 @ ~100$/hr flat rate shop time.. You think you can pull that all apart and put it back together in under six hours? Keep in mind that hourly rate is way on the low side, it's probably closer to 150. With an aged vehicle they wouldn't be out of line to charge a bit more than normal either to account for seized hardware.
Old Dec 8, 2018 | 11:48 AM
NYHumpinUtah's Avatar
Should'd could'd would'd
When I did the rebuild on the front end and rear end I should have changed out the hams to at least 488's Truck is still just a rolling frame so I guess I can still do it before I start putting it all back together. Man I hate doing it twice
Old Dec 9, 2018 | 07:24 AM
warmonger88's Avatar
I just had a set of diff assembled at a transmission shop last week. $600 for the shop to put together, $780 in new parts and install kits, and I used two old third member housings I already had laying around.
pat317az
13
Apr 22, 2014 04:45 PM
kirkerik
Jan 22, 2012 03:42 PM
ianshoots
Apr 27, 2006 08:15 PM
MorphiasX
Apr 15, 2006 09:38 PM
89red4x4yota
Mar 22, 2006 05:12 PM
