16.5 rock crawler wheels
Old Mar 9, 2009 | 06:08 PM
Paw's Avatar
Paw
Hello,
I did a search for any info on 16.5 x 9.50 or 10.0 wheels for a Toyota 6 lug, Does anyone make this wheel in a rock crawler ? Thanks ...Paw
Old Mar 9, 2009 | 08:26 PM
4Crawler's Avatar
Why 16.5" wheels? Those are usually for like 1 ton+ trucks with 8 lugs and they also typically lack a safety bead and so are very prone to losing beads if you air down very much.
Old Mar 10, 2009 | 03:06 AM
Paw's Avatar
Paw
I found 37 x 12.50 x 16.5 for very good price....around 400.00 for 5 tires with 90 % tred.
Old Mar 10, 2009 | 09:04 AM
DeepSeaSnake's Avatar
I'm in the same situation, as far as I know you basically have 2 options
#1 recenter hummer rims (and probably best since you can keep the run flats)
#2 (I just learned) Summit sells a set of basic steelies.
Old Oct 18, 2009 | 10:05 PM
82odyota's Avatar
anyone know of anyother places maybe someone that would custom make them
Old Oct 19, 2009 | 12:09 AM
muddpigg's Avatar
Looked on Summit for my 1st gen 4rnr with no look. Just make sure that you match the lug centric or hub centric. Back spasing will make a difference too.
Post the link up for Summit I'd like to look. 16.5 would open alot of options for me, living on Ft Lewis next to DRMO Would probably need to regear though.
Old Oct 19, 2009 | 07:10 AM
4Crawler's Avatar
http://www.stocktonwheel.com/4wd_offroad.htm
Old Oct 26, 2009 | 07:02 AM
ilovemyz's Avatar
just a thought...if you buy tires through a distributor you can get road hazard..if you crawl youve brobably cut a sidewall or two....road hazard!
Jun 1, 2021 01:51 PM
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
anniesball
Jul 30, 2015 12:14 PM
