Photography/Cameras Camera and photography advice
How many filters is too many?
Old Oct 4, 2010 | 05:07 PM
pattycakes77's Avatar
Ok, so I've got the UV filters on my lenses, but I would also like to use a polarizer for some outdoor photos, and some of those I would like to go black and white and use my yellow filter to enhance the contrast. So, do you really keep stacking filters on your lens or do they make combination filters, like a UV/polarizer, or better yet, a UV/polarizer/yellow filter? I've noticed that when I have my lens hood on but pulled back along with my UV filter, if I zoom all the way out I get the corners clipped on my pictures from stacking 2 filters on the lens. I would assume stacking the 3 above would be even worse, just wondering if anyone knows if they make combination filters or if you just have to stack and adjust the zoom so you're not clipping the corners from too many filters? I'm using my Nikon D60 with 52mm lenses. Thanks.
Old Oct 26, 2010 | 01:27 PM
cummins6speed's Avatar
Stacking filters will cause vignetting you will have to change filters when necessary
Old Jan 7, 2011 | 10:51 PM
eeejokesno's Avatar
Depends on the lens as to how many filters you can get away with. I always keep the UV filter on for protection, but I remove it when I use other filters. Film was sensitive to UV light, and it sometimes was hazy but digital sensors aren't, so the UV is just a protection thing.
Most lenses could probably do a polarizer and a coloring filter. Some could probably do all 3. The other consideration is an increased risk of flare and ghosting, especially with cheap filters. I use and highly recommend Hoya HD (meaning Heavy Duty) filters if you can afford them, or Hoya HMC Super filters for a bit cheaper. The HD filters are on all of my expensive glass because they are super strong, thin, and have fantastic light transmission. The Hoya HD polarizer also loses the least light of any polarizer available - about 1 stop.
Old Jan 10, 2011 | 09:01 PM
mokai's Avatar
Great advice eeejokesno...
JonG85
Jan 18, 2023 04:31 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
Davebarbier
Nov 3, 2015 03:28 PM
mreagen
Oct 5, 2015 04:27 PM
shredder4286
Oct 1, 2015 01:09 PM
