Domestic Swaps Chevrolet, Ford, ect
My Yota has the heart of a Pontiac!!!!!
Old 06-11-2010, 01:06 PM
Nashvegas Yota's Avatar
Here's the specs.....
Engine, 97 Pontiac Grand Prix GTP 3800 Series II Supercharged, stock internals, ported blower, 1" ZZP intercooler coming soon, 72 mm ported stock throttle body, deleted factory MAF sensor port, LS1 MAF, 3.4" blower pulley, custom 1 5/8" headers dumping to a single 3" pipe with high flow cat.
ECM, Same
Wiring Harness, modified 93 4 runner Harness (Mine had an accident when a previous owner tried to "fix" the air conditioning by putting a 30 amp fuse in a 15 amp hole.) New harness is from an SR5, so now it is wired for cruise and power windows, mirrors, and door locks.
Bellhousing, 99 Dodge Dakota 2.5 5 spd, 2wd (Has the correct bell pattern and used the same trans as yota.) with a new starter notch cut out on the drivers side.
Clutch, jeep plate, camaro flywheel and pressure plate.
Trans, Stock yota with a jeep ax15 input shaft, dakota front bearing retainer and flywheel.
The rest of the running gear is stock. (For now.)
Working on the oil pan today (Enlarged and modified to clear the differential.) then finishing up the wiring.
Old 06-11-2010, 01:10 PM
stockwell45's Avatar
dang you need a shop, and a new bumper
Old 06-11-2010, 01:28 PM
Leave my piece of a bumper alone dammit..... Nah, thats the next thing getting fixed after I get her running. The bumper was just something to keep people outta my radiator. I will finish it up though.... The bumper is actually a really nice start, 3/16" wall 4x4 tubing with 1/4" mounts.
Old 06-11-2010, 01:32 PM
MaK92-4RnR's Avatar
interesting choice for an engine... cant blame you for creativity
Old 06-11-2010, 02:13 PM
Swimmerboy2112's Avatar
No belt on supercharger = no boost lol
I'm sure you have one lol Sweet swap man, +1 for creativity!
Old 06-11-2010, 02:32 PM
Actually for the initial run I am not running a belt on the blower. Still has the stock 3.slow fuel pump. Boost-fuel pressure+heat=new pistons.
Old 06-11-2010, 02:36 PM
Good call my friend
Old 06-15-2010, 07:49 AM
So, I have been welding for a LOOOOONG time, and I must have forgotten every rule in the book. I used a stock oil pan as a base for the one in the truck. This worked great, it fit, did not leak when fille with water, etc. then I went to bolt it on and noticed how HORRIBLY the flange was warped. Worked for an hour to no avail, it was beyond repair. Soooooo. Dug thru my scrap metal supply, found some 16 ga, 1/8" and 1/4" plate. This is the beginning of my "bulletproof" pan. 1/4" flange, 16 gauge walls, and 1/8" floor.....
Old 06-15-2010, 04:30 PM
More oil pan pics....
The tubes are to access oil pan bolts without removing the starter.
Old 06-15-2010, 04:42 PM
yotaman85's Avatar
flux core rocks!! I was actually thinking of a 3800SC swap, glad to see it being done..
Old 06-15-2010, 05:04 PM
HighLux's Avatar
I dont know what that thing is....but its no longer a toyota.
Old 06-15-2010, 05:20 PM
JamesD's Avatar
To the original poster, you need to change the thread title. You truck has the heart of a Buick not a Pontiac
James
Old 06-15-2010, 05:42 PM
theMonch's Avatar
James
I was just thinking the exact same thing. : ) But seriously, good luck with the swap. ...And I am dreading my 3.4 swap, atleast I dont have to make an oil pan. : )
Old 06-15-2010, 05:58 PM
craneguy001's Avatar
wow that seems like alot more trouble than its worth
Old 06-15-2010, 06:23 PM
Don't know about that..... When the eng was in the car, with 3.29 gears, 15 psi (Non intercooled) curb wgt of over 3800 lbs, she ran consistent 12.5 sec 1/4 miles and got 26 mpg highway. This engine is a torque MONSTER, and the truck will be doing triple duty as toy, daily driver, and towing. The motor makes sense for all 3, good grunt for playing offroad and towing, reliable and relatively efficient for a driver. Not more or less worth it than other swaps people have done in the past.
Old 06-15-2010, 06:36 PM
94greenrunner's Avatar
dont get me wrong, I love the idea of a bigger/nicer engine. but when it comes right down to it, the 3.slow isnt that bad. but then again I have to bad of A.D.D. to finish something like that ha
Old 06-15-2010, 06:38 PM
to each as their own but torque is better than hp in a 4x4 thats why I got both an 02 built/blown 11.67 stang and a 86 yoda with a low gear to climb a mountain.... best of both worlds and not compermising in either. Good luck tho hope it works out
Old 06-15-2010, 06:59 PM
no bs tho whats the point of the blower with no belt?
Old 06-15-2010, 08:13 PM
Read much?
BTW, Rather have torque? The STOCK numbers on that motor were 240 hp and 280 Lb ft of TORQUE, it should be near 400 Lb ft with the smaller blower pulley, extensive tune, ported blower, and intercooler.
Old 06-18-2010, 07:15 AM
Kiwipushrod's Avatar
Wow, What a good idea!
Kiwi
Quick Reply: My Yota has the heart of a Pontiac!!!!!
