Domestic Swaps Chevrolet, Ford, ect
Fuel pump questions
Old Mar 18, 2012 | 02:24 PM
Dras16's Avatar
Fuel pump questions
When I first did this swap, I bypassed the in-tank pump and put in an in-line pump. That new pump sucks! So I was thinking about hooking the stock pump back up and running it to a regulator. What have you guys done for a fuel pump. Oh I cant use a mechanical pump as there is not enough room between the frame rail. Also what are you guys running for fuel lines? Hard lines or braided? I just picked up a bunch of fittings and braided line and planning on re-doing the plumbing. I am just looking for some other ideas. Thanks guys!
Old Mar 22, 2012 | 09:21 PM
thatsmyYOTA89's Avatar
That is a great question because I am almost at that stage in my 4.3 build. I am planning on running a fuel pressure regulator b/c I also do not want to run a mechanical. If you don't get a solid reply and/or get to it first I will let you know as soon as I get to it.
Old Mar 23, 2012 | 06:26 PM
Numbchux's Avatar
Originally Posted by Dras16
this swap
Which is.......
There are a lot of different combinations of fuel systems that require different pressure. If you don't bother to tell us what you have, all we can do is guess...which is pretty much pointless.
Old Mar 23, 2012 | 10:29 PM
I assumed he was talking about a carb'd 350 from reading his sig.
Old Mar 24, 2012 | 09:13 AM
Dras16's Avatar
Haha, yeah I guess I did forget to mention that! It is an 80's style chevy 350 with a carter carb. I dont know the cfm on the carb.
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
