Domestic Swaps Chevrolet, Ford, ect
Fuel draining back to tank overnight?
Old Mar 3, 2011 | 08:20 AM
Dras16's Avatar
I have a mechanical fuel pump on my chevy 350. I am puling fuel through the stock in tank fuel pump. After running it and then shutting it off the fuel will not stay in the lines. It drains back to the tank and has to be pumped back to the motor every time. Does anybody have any solutions for this?
Old Mar 3, 2011 | 11:19 AM
meswoleshane's Avatar
Your fuel pump is probably weak/worn.
Old Mar 3, 2011 | 11:29 AM
Dras16's Avatar
but its a brand new pump
Old Mar 4, 2011 | 07:52 AM
Do you have any pressure reliefs for the tank? I had the one on my old 88 clog up and it would cause it to run dry. I'd take off the fuel cap and there would be a ton of pressure. But, it would instantly work again...
If that's happening the vacuum left in the tank could cause the fuel to flow back.
Old Mar 5, 2011 | 08:03 PM
75k5toy's Avatar
I had/have that same problem with my old blazer, man that's a real pita. I tryied diferent fuel pumps, didn't worked , finally went with electric, now the problem is still there, but now just open the acc. switch, and wait a few seconds, then pump it a couple times and fire it up. salud
Old Apr 7, 2011 | 01:23 PM
Dras16's Avatar
Thats how i finally solved my problem also. Its not too hard either
Old Apr 9, 2011 | 01:58 AM
suncomb1's Avatar
Check your connections on your fuel tank, if the fuel tank was ever dropped or worked on. Even Toyota technicians have hooked up the fuel tank connections the wrong way.
Old Apr 11, 2011 | 06:29 PM
Dras16's Avatar
Yeah when i dropped my tank i found that one of the lines was kinked. Not good. fixed that and put in an electric pump. works good now
bigjstang
Jun 2, 2025 03:56 PM
colinmil
Jul 6, 2015 04:03 PM
Steezy96yota
Jul 6, 2015 10:00 AM
karbin
Jul 5, 2015 11:37 PM
elwood73
Jul 5, 2015 07:07 AM
