91 4.3l in a 81 pickup
So the manual transmission went out in my truck (81 toyota pickup 22r 5sp manual) and i might have my hands on a 91 s-10 4wd cheap but with an auto transmission. So my question is would it b worth trading the s-10 auto for a manual and try using the engine/manual trans and t/c out of the s-10??
i d prob get ride of the s-10 trans and t-case. if you want to go auto go 700r4 if you wan the 5 speed get the v8 one way stronger and lower 1st gear. go to advanced adapters and get the gm trans to toy t-case and run your toy t-case. the swap has been done so many times you can get everything and almost bolt it in. NWOR has the motor mounts and swap headers.
Banned 'cause I was 4runnerchevy also banned
If you don't go with the Toy case, then your not allowed around here anymore.
Most people want a manual, but most have never crawled with an Auto. Find someone with low gears and an auto, try it. I never though I would go to auto, but the first time I stopped in the middle of a steep precarious situation, I will never go back to burning clutch to avoid rolling back. It is a matter of preference though
You have some questions to ask yourself
Are you willing to destroy the Sonoma ?
Are you a fabricator ?
Are you good at electrical?
Is the truck a Daily driver, and do you have smog laws?
Can you be without both vehicles for the duration of the swap ?
My swap costed, me around $1500, that included the donor vehicle, adapter, and 700R4 tailshaft swap, and odds and ends. It would cost alot more if I didn't fabricate parts, and did my own wiring.
You need to also decide wether, your gonna go with the 4.3+Auto (the matched pair) or 4.3 + toyota 5 speed. Both adapters will cost you, Advance Adapters, is a good source.
I would get a swap manual from AA, Downey (although don't use downey parts), and even Jags That Run. This will give you a better idea on whats involved.
sandyota
Feb 4, 2021 11:16 AM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
