Domestic Swaps Chevrolet, Ford, ect
40 to 50 is my max road speed...help
Old Feb 1, 2015 | 07:39 AM
cstrode55's Avatar
Ok In 2hi I can only do 40-50 almost pegged out..here are my mods or at least what guy told me..1984 toyota 4runner,sbc swapped built 350,turbo 400 trans with toyota t-case,new bfg km2s 35x12.50×15 with less than 5 miles on them,new steel rock crawler wheels,5.29 gears,welded in front,Yukon spool locked rear,new elderbrock offroad avs carb,true dual Flowmaster exhaust, bilstein shocks,chevy leaf spring swap,marlin craw revolver shackels...any help or suggestions would be helpfull
Old Feb 1, 2015 | 08:16 AM
millball's Avatar
Put a stock 22r back in it. You'll be able to do 50, no problem.
Seriously, if your truck was only running on 5 cylinders, it should still go like a scalded dog.
If it's new to you, start with the basics:
Tune-up, compression test, ect. Find out where you're really at.
Old Feb 1, 2015 | 08:33 AM
JasonYota's Avatar
Pegged out as in what? Red lining the engine?
Old Feb 1, 2015 | 08:59 AM
cstrode55's Avatar
Yes...kinda like it stuck in gear but it shifts 3 tires..motor has plenty of power not bogged just high rpm
Old Feb 1, 2015 | 09:01 AM
cstrode55's Avatar
Would transfer case gears affect 2wd speed.it has a 7 bolt...I not a dumb ass just inexperienced in this area.
Old Feb 1, 2015 | 10:36 AM
JasonYota's Avatar
Do you even have a tach? Punch the numbers in a gear calculator and see if it's normal.
Old Feb 2, 2015 | 11:39 AM
rustED's Avatar
Transfer case gears would only affect your low-range, it wouldn't change hi-range/2wd. I'm no expert in figuring all the gear ratios, but I think your problem is the combination of the turbo 400 trans (3speed) and the 5.29 gears. You could easily get away with running stock 4.10 gears with the power of the 350, and the lower gears of the turbo 400.
Old Feb 2, 2015 | 11:47 AM
rattlewagon's Avatar
But it should still go faster than 50... Are you sure your not in low range?
Engine tuned up and running good?
Got pics?
Old Feb 2, 2015 | 12:08 PM
cstrode55's Avatar
Yes..in low it's even slower
Old Feb 2, 2015 | 12:10 PM
cstrode55's Avatar
People the engine is ok....I'm at high rpm at low speeds,plenty of power
Old Feb 2, 2015 | 12:12 PM
cstrode55's Avatar
Rusted....best in put yet..I agree with u
Old Feb 2, 2015 | 12:33 PM
JasonYota's Avatar
You should be going 118mph at 6k RPM. I'll ask again do you have a tachometer?
Old Feb 2, 2015 | 02:06 PM
skypilot's Avatar
TH400 is the same 1:1 ratio in 4th. That should fly, Is your trans slipping??? Is the fluid burnt?? Those tires and 5:29's may just be the problem or your speedo is way out.
Old Feb 2, 2015 | 02:21 PM
JasonYota's Avatar
A TH400 is a 3 speed. See my post above yours, pretty sure I could tell the difference in 50mph and 100mph without a speedo.
Old Feb 2, 2015 | 06:00 PM
skypilot's Avatar
Sorry; my point was TH400 3rd is 1:1 same as a 5spd 4th is 1:1 and the t-case is pass thru in 2 or 4 hi. That is a lot of power going into thin air.
According to this chart:
http://www.jeep4x4center.com/jeep-ti...atio-chart.htm
3500rpm you should be doing 65mph.
@6000rpm you should have your wings on.
TH400 2nd gear is 1:48 which makes your numbers look better.
So I am wondering if the transmission is not shifting to 3rd, or it is and the losses are converted into heat in the fluid. Everything else is heavy metal.
The T-case is solid gears, and the engine tach is god. I bet its not shifting into 3rd.
Old Feb 2, 2015 | 06:03 PM
cstrode55's Avatar
That was my first thought too...but it shifts 3 times
Old Feb 2, 2015 | 06:36 PM
skypilot's Avatar
I don't see any other place for all that power to go. A base 350 is 190hp. Smell test the trans fluid, it has to be burned. There simply is no place left for it go.
Old Feb 2, 2015 | 06:43 PM
cstrode55's Avatar
I have plenty of power,when the trans shifts it chirps tires,I'm just wound out like I'm in 4lo...I tried to search t400 with 5.29,I found drag racers like this setup for 1/8 mile...witch is about the distance I'm in high rpm,3500 to 4000...I seen some time slips with rpms,one was 73mph at 6900,so I think my tire/gear/trans setup is my problem...gona look into 4.11s and repost
Old Feb 2, 2015 | 06:48 PM
cstrode55's Avatar
I know creeping is a must,and my rig does awesome on the trails but it's just a pain to trailer it just for 30 miles away to the world famous Aetna mountain
Old Feb 2, 2015 | 06:59 PM
Yotard's Avatar
My 87 3/4 ton suburban had a 350 with th400 and 3.42 gear ratio your 5.29s are way too much for this set up. I ran 35s on my sub no problem at the stock gear ratio
