Domestic Swaps Chevrolet, Ford, ect
350 V8 swap pictures and info
Old Mar 22, 2012 | 06:50 PM
  #41
racerflea's Avatar
Why didnt u use stock pump with a regulator to begin with?
Old Mar 23, 2012 | 06:38 AM
  #42
Dras16's Avatar
Mainly because I was in a rush to get it running because I had to move. And I didn't have the money at the time to buy a good regulator. Also, I didn't know as much about it all as i do now!
Old Mar 23, 2012 | 07:20 AM
  #43
racerflea's Avatar
Ah!! Ok! Hey justin has it turned into one big puddle down there? Here in mississippi our rivers are WAY up!
Old Mar 24, 2012 | 06:05 AM
  #44
racerflea's Avatar
Btw how are u running your speedo??
Old Mar 24, 2012 | 09:15 AM
  #45
Dras16's Avatar
I was running the original speedo cable since I still have the toyota trans. I say "was" because my cable broke and haven't gotten a new one yet.
Old Apr 1, 2012 | 11:59 PM
  #46
ryan9376's Avatar
Hey just wondering what u had to do to wire it all up is it very complex
Old Apr 2, 2012 | 12:05 AM
  #47
ryan9376's Avatar
I have a 93 yota with sased with 1 ton axles a 76 sbc 350 4 bolt sm 465 4 speed and a np 205 t case just getting to the wiring part of it wondering what wires will be needed from my 22re harness any feed back would be awesome
Old Apr 2, 2012 | 03:42 PM
  #48
Dras16's Avatar
You need the wire for the starter, a power wire for the coil, and you need to wire the alternator. It's pretty simple once you get the wires pulled out of the harness. The hardest part I think is the alternator
Old Apr 4, 2012 | 01:38 PM
  #49
Justin Floyd's Avatar
Sorry I havent responded in a while. I used the stock pump with a regulator mounted to the firewall on the left side, you might be able to see it in the pictures.
Yea man everything in Louisiana is swampy, just the way I like it. It's killing me cause my truck is down with a front ring and pinion shattered to pieces. I'm definitely switching to an SAS this summer!
Also the wiring wasn't hard. Dras 16 is correct in what he said. If you go with a carburetor then all you got to worry about is starter wire, coil, and alternator. I used the original starter wire, I found a strong power wire that turned on with the ignition, and the alternator I ended up bringing it to a guy I know which wired it up correctly.
Old Apr 4, 2012 | 01:40 PM
  #50
Also I used original Speedo cable as well because I have stock tranny and transfer case. So far its holding up well, but I'm going to put it to the test in 2 weeks at Louisiana Mudfest in Colfax. If any of yall want to have a good time, look it up!
Old Apr 4, 2012 | 02:02 PM
  #51
racerflea's Avatar
Man if i had a 4x4 that was running i would!
Old Apr 4, 2012 | 03:25 PM
  #52
Dras16's Avatar
Man i would if i didnt live so far away!
Old Apr 4, 2012 | 05:40 PM
  #53
What happened to your rides racerflea?
well I should have everything done this weekend and running(if everything goes right). I have had to change the gears in the front and back, weld up the rear, and add traction bars in the rear to keep the axle from twisting.
Old Apr 4, 2012 | 06:39 PM
  #54
racerflea's Avatar
Just trying to do too much at one time lol doing a complete drive train swap is taking forever because i cabt find time to work on it and this weekend is a no go so it will be 2 mpre weeks before i get another chance to work on it
Old Apr 4, 2012 | 11:00 PM
  #55
racerflea's Avatar
If they have another atv fest i should ne able to maker it to that if im off
TheBFA
Feb 15, 2020 06:55 AM
1badyota350
Jun 28, 2015 06:50 AM
Anubiscougar
Jan 23, 2007 01:47 PM
yotamaster1988
Nov 30, 2006 05:53 AM
TOYOTA4LIFE
May 26, 2005 05:31 AM
