Diesel Swaps Diesel engines
91 2wd om617 swap
Old Nov 4, 2013 | 06:46 AM
draggin209's Avatar
91 2wd om617 swap
Whats up guys gonna start a build thread here on my swap. My yota is the complete opposite of your guys' firstly its bagged and body dropped fully shaved and getting an om617. Using the tdswaps kit it actually fit very nicely besides a few small things like the power steering mount an throttle adapter.
Motor mount
The motors
Old Nov 4, 2013 | 06:48 AM
draggin209's Avatar
Bought both motors for $500 off cl in april then just cleaned up the one gotta order some gaskets still. I did test fit it to see how it fit an its real snug.
This is how high it comes above the fenders/hood
Old Jan 4, 2014 | 10:32 PM
draggin209's Avatar
So I realized my steering damper is gonna go into the cast oil pan. So would there be any issues by me mounting the one end lower?
Old Jan 5, 2014 | 10:39 AM
waltt's Avatar
I just took mine off. It drove just fine with 33's on it. Didn't even really notice that much of a difference.
Old Jan 5, 2014 | 10:43 AM
draggin209's Avatar
Might have to just take it off. Do you think It'd cause problems by lowering the frame mount?
Old Jan 6, 2014 | 08:25 AM
waltt's Avatar
No you should be fine. I don't think the placement is very critical On the steering stabilizer. Are you going to go for a hood scoop on your truck. Your engine almost looks like a blower sticking out of the top of ur truck. Looks mean!!
Old Jan 6, 2014 | 08:33 AM
draggin209's Avatar
Im just gonna lower the frame mount on it. Feel like I should keep it. For now im just gonna cut a hole in the hood. It does look mean sticking out like that. If I ran a hood scoop it would have to be reversed and I think itd look funny cause the back of the motor will clear the hood
Old Jan 6, 2014 | 08:48 AM
waltt's Avatar
You could always take some Cardboard and mock up with you like. Then just glass over that Once you get what you want.The possibilities are endless. Good luck with your build man.
Old Jan 6, 2014 | 09:07 AM
draggin209's Avatar
Ya they are its gonna be primarily a summer/spring vehicle. or whenever its or raining. So the hood doesnt really bother me. Theres really no way around the hole thats for sure. Thanks man. Its coming along slowly
Old Feb 17, 2014 | 06:31 PM
draggin209's Avatar
Got the motor in finally with the clutch and flywheel. Just need to get some belts and figure out where to mount my oil cooler. Plans were in front of the radiator but I forgot about the electric fans so now I need to find a new place. Anyone know the part number for the belts?
Old Mar 12, 2014 | 02:00 AM
cheap-ass's Avatar
There's something wrong with your motor mounts because I have TDswaps motor mounts and my motor is way lower than yours granted my truck was a V6 truck to start and it is 4WD but still just look at the difference.
Old Mar 21, 2014 | 09:05 AM
draggin209's Avatar
Nope motor mounts are good. Truck is body dropped and has a Z. So motor is pushed up higher
Old Mar 21, 2014 | 09:07 AM
draggin209's Avatar
New stack is on its 4" stainless
Old Mar 26, 2014 | 07:00 AM
draggin209's Avatar
Pulled her out today for some sun
tuckin a little lug
RatOmeter
Oct 22, 2015 03:17 PM
WellsR
12
Jul 31, 2015 03:27 PM
GeoRoss
Jul 24, 2015 03:03 PM
colasurdo
Jul 16, 2015 11:32 AM
hexrain
Jul 12, 2015 01:13 PM
