All Other Toyota Swaps I4, I6, Lexus V8
Official 1JZ/2JZGE 2JZGTE Swap thread
Old Mar 5, 2013 | 07:22 PM
  #61
96 DuneRunner's Avatar
WOOOOHHOOOOO ITS HERE LOL FINALLY!!!!!!!!!!!!!! Hahahaa ok so on the left is big brother on the right is like, well like that cousin that's cool with a little time and effort it could be really cool...... lol
Official 1JZ/2JZGE 2JZGTE Swap thread-forumrunner_20130305_232013.png
Official 1JZ/2JZGE 2JZGTE Swap thread-forumrunner_20130305_232030.png
tlivi
Old Mar 5, 2013 | 07:23 PM
  #62
Also I have a crap load of 4runner parts if anybody needs anything oem just let me know thanks y'all again will keep updates on the build my bday is in april that is my goal to have it rippn by.......
tlivi
Old Mar 7, 2013 | 05:25 PM
  #63
8784 runner's Avatar
Community Builder
Old Mar 9, 2013 | 12:21 PM
  #64
Getting ready to drop it in engine bay is ready for installation
Official 1JZ/2JZGE 2JZGTE Swap thread-forumrunner_20130309_162121.png
tlivi
Old Mar 9, 2013 | 08:57 PM
  #65
Got it in lol
Official 1JZ/2JZGE 2JZGTE Swap thread-forumrunner_20130310_005742.png
tlivi
Old Mar 9, 2013 | 09:10 PM
  #66
Hehehehe. !"""""!!!!!!
Official 1JZ/2JZGE 2JZGTE Swap thread-forumrunner_20130310_011010.png
tlivi
Old Mar 14, 2013 | 11:17 AM
  #67
Bingle's Avatar
Scribed! Seriously concidering a 2jzgte in mine. Any links or known swaps that used the supra auto and the inchworm t-case adaptor? I like my stick but the auto seems "easier" and probably cheaper. Opinions?
Old Mar 15, 2013 | 12:09 PM
  #68
niall's Avatar
Not likely cheaper, the Inchworm adapter is not cheap. Easier? If you're leaving the 2j stock, it's not that bad. I like my auto for offroad though.
Old Mar 18, 2013 | 06:29 AM
  #69
Bingle's Avatar
I assume that means that you're using the adaptor? No, not cheap, but I don't "know a guy" who has the right trans and bellhousing and input shaft, clutch, ect. just laying around that he'll let me have for $200. I figure sourcing all the parts for the r150/151 hybrid would cost me as much or more than the inchworm adaptor, plus, an auto might be nice for a change.
I plan on staying stock with the engine, at least at first. Possibly change over to usdm spec turbos and injectors when/if the jdm ones go out. Would do some mods to let the engine work "better" but not planning to try to get more than 350hp tops. At least that's my current thoughts. What are you running and how do you like it? What would you do different?
Old Mar 18, 2013 | 11:33 AM
  #70
niall's Avatar
What would I do different? Buy a fiesta, never pick up a wrench, and probably hang out in my california beach house by this point. Haha
All kidding aside, I have always prefered an auto transmission offroad, so I'm a fan of that route forsure. If you're going to keep the 2jz in that BPU range, the stock supra/aristo a340e (in good shape) will hold up fine.
Old Apr 14, 2013 | 06:34 PM
  #71
Vudujoose's Avatar
So out of curiosity what have all of you that have done the 2jz swap with a w56 trans done about the rear drive shaft? I am considering this over my 1uzfe (parts are much cheaper for the 2jz) and it will be going into a 95 4runner with a factory automatic (ewww a340h). Should I look for a 4cyl 4runner (manual) drive shaft?
Old Jul 8, 2013 | 12:38 AM
  #72
David Groufsky's Avatar
Will a 2.8 5mge flywheel fit on a 2jz-ge motor and work well??
Old Jul 8, 2013 | 09:13 PM
  #73
I would also like to know if the 5mge bell house will fit to a 2jz-ge motor i hope it does it would save me $$$
Old Jul 9, 2013 | 03:31 AM
  #74
suppra87's Avatar
That's a negative to both of those questions. The only flywheels what will bolt directly to the 1JZ/2JZ motors are:
-93-98 MK4 Supra turbo v160/161 6-Speed flywheel
-93-98 MK4 Supra N/A W58 5-speed flywheel
-90-92 JDM MK3 1JZ R154 flywheel
Same goes for the bellhousings. The 1JZ and 2JZ share the same bellhousing bolt pattern but they are the same as each other and no other engine.
Old Jul 9, 2013 | 10:20 PM
  #75
Thanks my man
I found a real 2jz-ge bell house to mate to a w56 box it cost me $300 nz so say about $250 u.s
Old Jul 11, 2013 | 12:02 AM
  #76
Parts to add horse power
Hi i would like to know of any ways to easily add more horse power to my 2jz-ge motor so i can give my truck more mud ripping power lol
Old Jul 12, 2013 | 05:19 PM
  #77
clutch kit
I would like to know what clutch kits ppl are doing for the 2jz-ge motor with a w56 gear box????
Old Jul 14, 2013 | 01:14 PM
  #78
91_TOYOTA_4x4's Avatar
^^^ man have mercy on that w56 lol that things probly going to be thrashed in a few months behind a 2JZ.
As far as making lots of power with a GE i think u bought the wrong 2JZ lol get a turbo GTE and the sky is the limit. Otherwise i would just get a header/full exhaust, and maybe toss some cams in her.
Or... get a real 2JZ with turbo/turbos on her
Old Jul 18, 2013 | 10:56 PM
  #79
thanks man. What box do you think i should use for my 2jz-ge? P.S My 2jz-ge is 250 HP
Old Sep 4, 2013 | 08:27 AM
  #80
t100 noob's Avatar
2jz into t100?
so new to the t100 fields, just did some small work to get a 3in lift (ball joint spacer tortion bar and 3in block in rear.. sittin pretty on 33x12.5xr15)
now however comma....
i do alot of towing, and before soemone comes along saying sell the pos and buy a tundra... no... i love these t100's if not them, then an older pickup dlx or sr5. fun!
so my question is. 2jz or 1jz. will either one bolt up to the existing tranny and transfer case, or do i need to switch? and whats a w series? sorry lots of new verbage as looking to ditch this 5vz and switch to a turbo compatiable engine
cheers!
HN joyce
