All Other Toyota Swaps I4, I6, Lexus V8
85 body to 92 body but keep the 85 frame help is it worth it
Old Jan 20, 2008 | 02:57 PM
straightaxle's Avatar
I just bought a 92 4x4..the frame where the control arms go is completely rusted...i have a 85 straight axle i bought new, it has been a tough truck and was built in japan..they say the straightaxles are better....i was wondering if this could be done fairly easy...these are both regular cabs..the only thing is that i am missing the doors for the 92 model, i can try and find some of them cheap....was wondering if can be done, the problems i will run into , and is it worth it.....my 85 has serious rust issues but run and operates like a champ....around the windshield i have black urathaned it to stop the leaks that i have around the windshield.... if it can not be done waht about the bed....i hate to part with this truck, i have a new chevy hd2500 duramax and rather drive my 85 beater.....any input will help out alot....i pretty much know these trucks ....but is this worth it......trying to save my truck.....the 92 i sold the engine it only had 67k on it ...what i have been seeing is that the 22r carb last longer than the 22re fuel injected.......someone said that i could take the 85 axle and weld it in the 92...sounds like alot of trouble to me....what would you pros do in this case.....hope you can encourage me to do the correct thing......please email me back.....also can email me at blown@comcast.net....thanks jeff
Old Dec 31, 2008 | 07:14 AM
b/s rules's Avatar
the 92' has a wider frame than the 85'. the cab swap can be done with help of some welding and fabbin or a small body lift. i put a 85' straight axle under my 91' and it wasn't as bad as you might think. kinda pricey if you buy the swap kit, but we built most of my brackets and such. i had to buy the frame jigs and crossover steering and practically built everything else for it. except the springs of course. just keep in mind that doing the front also requires a lift for the rear. from one kentucky "hellbilly" to another.
gieselman
Mar 20, 2016 04:34 PM
Sep 4, 2015 09:27 AM
Feadship
Aug 1, 2015 12:18 AM
Backcountry411
Jul 24, 2015 08:06 AM
yourrealdad
Jul 21, 2015 11:13 AM
