All Other Toyota Swaps I4, I6, Lexus V8
turbo or super charged 22re
Old Nov 9, 2008 | 07:43 PM
NastyNate71's Avatar
i was wondering if any one has a super charged 22re nad if you think its better than a turbo sense you have a constant boost and don't really have to rebuild them after a couple years?
Old Nov 9, 2008 | 07:59 PM
Hayes's Avatar
Turbo is factory. Supercharger is expensive and it takes power to make power.
That being said, I think I would go supercharger because it is more on demand than turbo (generally speaking).
Factory turbo parts can be found for fairly cheap though.
Old Nov 11, 2008 | 07:25 PM
if i went turbo i would have to do wireing and my compression is to high but the kits at LCE are both 3000 bucks............and its a instant 64hp gain
Old Nov 11, 2008 | 08:07 PM
ozziesironmanoffroad's Avatar
id say turbo cuz its cheaper and would be more worth the HP gain than spending 3000 dollars on a supercharger, when you could use that 3000 for tires, rims, sliders, etc.
Old Feb 24, 2009 | 08:16 AM
RallyToy's Avatar
I ran both both types of forced induction on a 1994 22RE 4x4 5 Speed.
The Camden supercharger that LCE uses in their kit is very old technology, with no bypass valve, like the Eaton/Magnacharger (TRD) does in Tacomas. This lack of bypass valve and the straight cut of the lobes gives it terrible gas mileage. I saw easily as low as 12mpg with the supercharger. A bit of an easier install, though, than the turbo, and great low-end torque.
The turbo, with the intercooler, actually improved my combined city/highway gas mileage by about 2 mpg so I was getting about 23-25 mpg. It also pulled way harder at any comparative boost level to the supercharger, probably due to the lack of intake air temps. Install necessitated a local welder to attach the downpipe and wastegate pipe to the exhaust. A much more involved install with much better results. I would recommend getting the CNC'd manifold LCE kit over their tubular-style one.
For either, you will have to provide more fuel and be able to retard the timing at anything over about 3-4 psi, at least that's how it was for my truck. It's a lot of money to spend for only 3-4 psi run off of the factory computer.
I would suggest LCE's MAF conversion from the later Tacoma 4 cylinders in conjunction with URD's "5th Injector" kit. This will allow you to control fuel and timing. You will need a hi-flow fuel pump as well as a way to monitor the Air/Fuel Ratio.
You could also go the stand-alone engine management route, but that requires tuning at a pretty complex level.
It's definitely worth it. Boost puts a smile on my face every time.
Old Feb 26, 2009 | 09:34 AM
annoyingrob's Avatar
If you can't decide, just do both.
Twincharging FTW.
Old Feb 26, 2009 | 03:49 PM
stangr351's Avatar
I have a friend who bought a eaton supercharger off of a t bird supercoupe and built a manifold to bolt it on too
he is using supra injectors and maf and a stand alone mega squirt system he built using there kit. I think he is using a supra fuel pump as well.
it is all in an 84 celica
Old Feb 26, 2009 | 04:59 PM
arizonaguy's Avatar
turbo or supercharger
im not sure but i think a turbo might be cheaper
88sasturbotoy
Jan 30, 2026 01:57 PM
RatOmeter
Oct 22, 2015 03:17 PM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
toofly1999
Jul 25, 2015 07:09 PM
PlayAwhile
Jul 20, 2015 11:36 AM
