All Other Toyota Swaps I4, I6, Lexus V8
2.5 1JZ swap
Old Aug 29, 2010 | 07:07 AM
  #41
birdduck's Avatar
your fuel problem could be something simple like a regulator or a fuel filter?
oh and a tip that i myself like to do you may already know this but you can use
rtv(gasket maker) to help seal up your exhaust at the flanges, i used it to seal my wastegate of my integra and never had any issues as with the flanges on my runner.
Old Aug 29, 2010 | 08:02 PM
  #42
SupraRunner's Avatar
It drives!!!! I took it out and rode around a little tonight. Still have a lot of issues but I can drive it around now. Still going easy on it right now, one to break it in but two it scared me a little the one time pushed it harder. As far as the transmission it was not shifting due to the speed sensor so until I can rebuild the other one I have I just disconnected the solenoids and shift it manually. The TPS is bad but the MAP was just a bad conection. I took a video tonight, not to good but I will load it tomorrow.
Old Aug 30, 2010 | 05:00 AM
  #43
birdduck's Avatar
i know the feeling!.. when i first drove mine i backed it up and then pulled it back into the driveway... not much but its the feeling of accomplishment that you got that far.
now get those parts fixed and see how she goes.
Old Aug 30, 2010 | 06:47 PM
  #44
I still have a lot to do, I am waiting on the inter cooler that i will use. I hope to get the stock tach working so thats why the big one is temporarily in there. I need to swap the end cap on the tail of the transfercase to get the cable driven speed sensor to work. I know the videos suck and i will try to get better ones.
Old Oct 15, 2010 | 11:45 AM
  #45
boomyanker's Avatar
Any new progress?
Old Jan 27, 2011 | 02:52 AM
  #46
adiga4runner's Avatar
hi man ?
hi man how are you ?
can u tell me what kind of transmission you uased for the 1jz swap to fit the 1jz engine in the 4runner and is the 4x4 system in your 4runner work with the engine ?
can you help me bro ?
thank you
Old Nov 5, 2011 | 03:29 AM
  #47
motorhead's Avatar
updates? Curious to see how this worked out...
Old Mar 18, 2012 | 07:41 PM
  #48
MaDkAtT44's Avatar
howz progress??
nvdesertrunner
May 11, 2020 08:18 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Dakotaneu
Jul 27, 2015 12:03 AM
GeoRoss
Jul 24, 2015 03:03 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
