All Other Toyota Swaps I4, I6, Lexus V8
1UZFE swap into 2nd Gen 4Runner
Old Dec 2, 2005 | 05:12 PM
  #361
DH6twinotter's Avatar
Man, you've got me really wanting to do this now. :cry:
Looks great!
Old Dec 2, 2005 | 06:41 PM
  #362
DudeBud's Avatar
you like that silicon dont ya looks good keep them coming
Old Dec 2, 2005 | 06:59 PM
  #363
Cebby's Avatar
I think I'm going to pull it off and redo it with less. I was following the directions on a writeup, but it looks like there's way too much tho.
Here's the pic from the writeup:
I thought mine looked the same...
Old Dec 2, 2005 | 07:16 PM
  #364
DudeBud's Avatar
i wouldn't worry much. you sould see what my uncle does :pat: both surfaces like what you done with the water pump and he's been doing it when he started building motors before i was born. i try to use little as possible. a tube will last me quite awhile.
Old Dec 2, 2005 | 07:36 PM
  #365
Cebby's Avatar
I'm worried about the damn thing leaking and then trying to dismantle the motor in the tight 4Runner engine bay. You have to take apart half the motor to get to the pump. That engine bay is tight with the V6, let alone this behemouth...
Old Dec 2, 2005 | 07:57 PM
  #366
DudeBud's Avatar
I really think it will be ok since it has that groove that goes around the surface but, it's your motor.
is that a copper type rtv you are using?
Old Dec 2, 2005 | 10:23 PM
  #367
Robinhood150's Avatar
My friend and I thought it was a little much. All that stuff that squished out also squished in. Also, aren't you supposed to put the RTV around the bolt holes too?
Old Dec 2, 2005 | 10:37 PM
  #368
4RocRunner92's Avatar
How big of a gas tank are you using?
Old Dec 3, 2005 | 02:08 AM
  #369
Cebby's Avatar
I put it where the groove is on the water pump per the directions I had. There was no groove the whole way around all the bolt holes.
Old Dec 3, 2005 | 02:09 AM
  #370
Cebby's Avatar
Yes. The directions I had said use high temp sealant. The copper stuff is good to 700 deg.
Old Dec 3, 2005 | 02:10 AM
  #371
Cebby's Avatar
I have the stock tank currently. The E250 tank I plan to do later is roughly 20 gallons.
Old Dec 3, 2005 | 03:43 AM
  #372
Cebby's Avatar
This AM, I went down and pulled the timing belt off and pulled the pump. Took all of 5 minutes...
There was a nice "squish" in two areas on the inside of the pump (pulled off before taking the pics-oops). Lesson learned. It still wasn't fully set up yet in some areas...
Old Dec 14, 2005 | 04:29 PM
  #373
Cebby's Avatar
OK, take two...
Here she is all cleaned up.
The copper RTV was a major PITA to remove from the pump (those grooves do a nice job of keeping the RTV in there. At least I learned from it.
Considerably less this time, plus I smeared it around to make sure it was even.
Side view
Waterpump back on (sorry a little fuzzy)
Got the thermostat housing back on also (a pre-schmear pic...)
Even got the cams lined up properly while installing the timing belt this time.
Idlers reinstalled also...
Crank pulley and cover back on too
This is as far as I got yesterday (I did this AFTER replacing the waterpump, thermostat and changing the oil on my 2000 JGC)
Old Dec 14, 2005 | 07:16 PM
  #374
That's going to be a sweet rig when all done!
Old Jan 9, 2006 | 07:39 PM
  #375
HOJU's Avatar
How's it going with the build Cebby? I doubt it because of the holidays, but are there any updates?
Old Jan 9, 2006 | 07:41 PM
  #376
Your crazy Cebby. lol
Old Jan 10, 2006 | 06:52 AM
  #377
99_Runner's Avatar
Looking good. Now you just have to get the old motor and trans out of the 4Runner so you can start making some really big progress steps.
Old Jan 10, 2006 | 08:23 AM
  #378
Cebby's Avatar
I was planning to work on it all day yesterday, but was hsopitalized for about 24 hours starting Sunday night.
My next steps (in order) are
1. pull the motor and trans
2. wrap up the motor items
3. build up the doubler
4. work out the motor mounts
5. work out the cooling
6. work out the fuel lines
7. work out the exhaust
8. wire it up
9. get the drive shafts modified
10. smoke the tires
Old Jan 10, 2006 | 08:49 AM
  #379
mt_goat's Avatar
Bummer dude, you ok?
Old Jan 10, 2006 | 10:35 AM
  #380
99_Runner's Avatar
Sorry to hear about the hospitalization. Hope that everything is ok.
