1UZFE swap into 2nd Gen 4Runner
#322
This shows how to machine one from a dual v-belt pulley. Machining a Dual V-belt pulley to fit a 6 groove serpentine
Here's a place that will machine custom pulleys... Emachineshop.com
#323
Originally Posted by Cebby
I have a Jeep GC also with the 4.0 I6. It is a nice motor, but only slightly less thirsty than the 3.0 in the 2G 4Runner. (Granted my JGC has crappy gearing though).
The AW4 and A340X are both made by Aisin. I don't have a problem with the AW4 being in a Jeep. I'm trying to avoid dismantling the entire trans if at all possible. Swapping outputs requires this. Plus, I already have the Toy cases and they are plenty capable of taking abuse.
My IFS will be the weak link in this rig once the swap is done. Especially now that I picked up the Tundra TC.
the swap you're doing is really cool to watch man, I just picked my self up an 89 4Runner, so I know about the IFS weakness, but an SAS and a diesel swap of some sort will work all that out... I'm thinking 3.9L Cummins...
once again, it's really cool to see this swap of yours take shape, great pics, and alot of tech knowledge is a great thing for us beginners...
cheers and No worries
Dave
#324
Got tied up with stuff - back to it this week hopefully.
It appears that the AC pumps I'm finding are R134 for the 1UZ. My 4Runner was R12. Are there other components I need to switch out along with the pump, or can I reuse what I have?
The other thing I'm finding is regarding the alternators. Do I have to use the LS400 alt with the heat shield, or can I use an SC400 alt (no heat shield).
Anyone know if the 1UZ and 2UZ accessories are interchangable? (PS Pump, AC Pump, alternator)
#325
Wow, that's awesome! That's impressive. I wish I had the talent to do that kind of stuff. I've been wanting to do a 1uz, 2uz or 7mgte swap for a long time now. Looks like a really nice project!
I think the 1uz is one of the nicest looking modern engines out. I really like the design of the plenum and valve covers with the hidden plug wires. Have you thought about polishing the valve covers and plenum? Would look really cool.
I had an idea for your drive shaft bolts. I've never had to do it, do this is probably stupid, but here goes: Could you put a breaker bar on the bolt you are trying to loosen and just push the vehicle? If you let the end of the breaker bar rest on the floor, then the motion of the 4runner would turn the drive shaft loosening the bolt. Maybe it's dumb, but I'm just trying to be creative here.
Does the 1uz require premium gas? I thought I read somewhere that it does.
Well, have fun all.
Daniel
Well, have fun all.
Daniel
#328
OK, I found a PS pump and a Alt locally for a reasonable price, but ran into a question on the AC pump.
The salvage yard I was speaking to said the AC pumps were the same for 90-92, then different for 93-97. They have a 92, but I think my engine is a 94. He said there is a difference with the clutch pulley and suction tube (?).
can anyone shed some light on this?
#329
Cebby,
During the early and mid '90s Toyota was making the switch from R12 refrigerant to non-ozone depleating R134 in thier A/C systems...this is probably what is responsible for the differences in parts.
The 'old' R12 is a more efficient system that allows the use of smaller parts (pump/compressor, condensor, etc.) at the drawback of destroying the ozone and (now) being damn expensive. Sometimes switching over old R12 systems to R134 results in reduced cooling ability due to R134's lack of efficiency and the smaller R12 parts.
For the sake of cost the R134 parts off of a later model would probably be desirable. The 'suction tube' is the flexible line the goes from the cooling unit (in the cab) to the A/C compressor. Be sure to save yourself a headache or two and replace all the O-rings, questionable hoses, etc. along the way. Good luck.
#331
...snip....
...snip....
Premium gas - I think I knew that. I'm curious to see if I'll get any gas mileage improvements with this combo. It is a pretty efficient engine, so hopefully...
#332
This may or may not help- I toyed with the Idea of converting my ford (cough) exploder from the R12 to the R134. I was told by my dad's mechanic that the condenser is different between r12 and r134. He mentioned that if I just flushed the system and added R134 I would have heating problems, such as mentioned above, and the system would not cool as well as the r-12.
I think the tubes inside the condenser are different sizes for the different coolants.
In the end it would have been a wash cost wise to repair the r12 completely or retrofit to the r134, I opted to stay r-12 because the AC was crappy enough in that vehicle.
However, living in Phoenix, ideling in traffic at 4:00 PM on 115 degree day, my toyota (r134) A/C has kept the cab nice and cool. In the Exploder I would have been melting...
If you have a descision, I might lean toward the r-134, cheaper for one, and being you might have some trial and error in putting the whole thing together, it might be the more economical/easy route. Lots of shops have refrigerant capture equipment and will credit you for what they suck out of the old system. Talk to an A/C guy for sure to see if I am correct on the condenser issue
#333
Originally Posted by Diesel_Freak
I'm a big fan of my Toy... don't get me wrong, but as far as gas motors go, I'll take a 4.0L mated to an NP242 over nearly anything else...aside from the Original FJ inline 6, there has never been a sweeter engine sold in a 4x4...4.oL's are flat out BALSY... add a supercharger and they'll smoke built v-8's... I love my 22RE to death cause it motors around very nicely, and it get's great milage, but my Cherokee has the motor that dreams are made of...not to mention the NP242 being one of the best all around T-cases made in the last 10 years......
#334
There is a company out there that makes a supercharger for the 4.0. I think they are called Advenger Superchargers. I think that if you put that supercharger on top of a bored and stroked "4.6" then it would be a tough motor to beat.
#335
Originally Posted by Randomness
Except that last time I owned a ZJ with the 4.0, NP242, and AW4, there are no blowers for the 4.0. It's a great motor, for sure. Nice torque, good reliability. But it's not a speed demon. It won't smoke built V8's. Try to tell anyone on JeepsUnlimited that. The 5.2 and 5.9 both have available blowers, but nothing for the 4.0. Now, if anything has come out in the last 6 months, then I take it back. But I've heard nothing.
http://www.lextreme.com/ everthing you ever wanted to know about these motors
cebby: hows the progress going? im following this with intrest as i am seriously considering this swap myself, keep up the good work. btw, im sure you probably have already seen this, but just in case here is a link to someone in who has a running 1uz in a 2nd gen hilux surf.
http://geocities.com/deonsv8hilux/
edited the power output of the single turbo setup, was a little off, my bad
#336
Hey Moto - The process has been non-existant recently. Had some other things to take care of - but in the mean time, I've been ordering/obtaining needed parts. I picked up an alternator and PS pump a couple of weeks ago. Just need an AC pump and I'll be good to go.
I'm active over on Lextreme also - as a matter of fact, I'm expecting a shipment from Lex from over there at the beginning of next week. Starter rebuild kit, timing belt, plugs, wires, etc, etc. I'm going to do the big maintenance items on the motor now, while it's out of the rig.
The great power to weight ratio was one of the many pros to doing this swap. Basically, I'm removing Toyota's WORST engine (3VZE) and replacing it with arguably the best engine Toyota ever made.
It looks like the hoist is finally freed up, so I'm hoping to pull the motor this week (FINALLY!!!) and start test fitting the 1UZ. I need a few snap rings for the t-case, but other than that, should be good to go.
#337
#338
Rocket - Name a worse engine made by Toyota than the 3VZE.... I'll give you the fact that its better than most other motors by OTHER manufacturers. Wasn't Toyota's finest hour though... Mine gave me 140K miles with zero issues - geared properly, it isn't a total turd.
#339
Cebby been reading you swap on this board and marlins, don't know if you have already stated this or not but is it possible to mate this engine to a R151 or do you have to do an auto. also what are the best vehichles to get this engine from ie. Lexus or toyota?
thanks
Late
Joe
thanks
Late
Joe
#340
its from a early 90s lexus sc400 or ls400, the only difference is the oil pans, and yes you can mate it to and 5-speed with a bellhousing from dellows (in austrailia) but its pricey, you could try to just make you own adapter plate
