All Other Toyota Swaps I4, I6, Lexus V8
1989 Pickup 1uz-fe/auto/dual t-case swap
Old May 29, 2012 | 02:25 AM
  #121
99 sas runner's Avatar
I'm getting close to brob finished swapping a 1uz in my 99 4runner, I also just kept my auto. Do you like it offroad with the 1uz? I've got duals with 4.7s behind my auto already.
Old May 31, 2012 | 04:48 AM
  #122
toyminator2000's Avatar
I love the 1uz and the auto. The only complaint is the Lexus power steering pump isn't as strong as the trucks. With a manual tranny you can feather the clutch to bring up engine rpms to help the pump but you can't with an auto. It definitely needs hydro assist.
Old Jun 12, 2012 | 07:28 PM
  #123
RMA's Avatar
RMA
hows it going man .. question for you if you dont mind .. what brand and part number are the Urethane mounts your using here and how are they working for you ? looking to use something like this right now .
Old Jun 13, 2012 | 04:07 AM
  #124
They are working great so far. No complaints whatosever. The way I am using them they are stiff but that's the way I wanted it.
They are for an RX7 application made by a company called Banzai Racing
http://www.banzai-racing.com/cgi-ban...r+mounts&Go=Go
It was one of the top two on that page, I can't remember which. I did have to drill out the center hole a bit bigger for the 1/2 bolts I used. Had to bore out the Lexus mount slightly too to match.
Old Jun 18, 2012 | 10:53 PM
  #125
Smitherz's Avatar
Just wanted to chime in and say my Lex 1UZ power steering pump is fine hooked up to my Tacoma steering rack. When I was doing my swap I went ahead and bought a remfg. pump from my local Carquest and it works perfectly. Yours could easily be worn out? Just a thought. It's a lot cheaper to get another pump and try than have to fab or add something different.
Old Jun 19, 2012 | 06:55 PM
  #126
I have two or three pumps. Their just not designed for 37" boggers on rocks. I have a hydro assist ram kit I'm just waiting to install it because I have an FJ80 front axle I will be installing.
Old Jun 26, 2012 | 09:39 PM
  #127
Smitherz's Avatar
Now it all makes more sense. You are headed in the right direction with the new axle. Awesome.
Old Jun 29, 2012 | 01:45 PM
  #128
yotasavg's Avatar
Still one of my favorite builds! Are those the toyota fiberglass high clearance fenders? I re-read from page 2 but may have missed it...
Old Jun 30, 2012 | 04:42 AM
  #129
Hanemmann Fiberglass
http://www.hannemannfiberglass.com/c...457567&page=17
Old Jun 30, 2012 | 07:18 AM
  #130
yotasavg's Avatar
Right on ok, we're they pretty painless to true up?
Old Jun 30, 2012 | 04:19 PM
  #131
No, they were pretty much a pain in the ass to make the body lines and gaps match.
Old Aug 18, 2012 | 06:42 PM
  #132
NorthIdahoyota's Avatar
How stiff are those urethane mounts? You said they are a little stiff, but would they be too harsh for a dd? I really like your motor mount setup.
Old Aug 20, 2012 | 05:45 PM
  #133
The 1uz engine is very well balanced and runs extremely smooth throughout it's entire rpm range so it feels fine driving it. You might notice more engine vibrations on a lesser engine though with these mounts used the way I'm using them.
Since I'm running a single bolt straight through the mount instead of isolating it it's gonna transfer some through to the frame and body.
Old Aug 27, 2012 | 02:22 AM
  #134
89lc's Avatar
These are the mounts that I used on my 1uz. I can't tell you how much vibration they transfer as I haven't started it yet, but they are pretty big and the poly is the only thing touching the mount bracket. I pretty much mounted them like toyminator2000.
http://www.energysuspensionparts.com...-Isolators.asp
Old Sep 5, 2012 | 04:35 PM
  #135
xTRDKenny92's Avatar
I have my engine bolted directly to the custom mount i fabbed up. there is not much need for a bushing in my opinion. this motor has just about no vibration at all. car friends cant even tell there was no bushing, surprised a bunch of people.
Old Sep 6, 2012 | 09:42 AM
  #136
89lc's Avatar
I got mine started and it has no vibrations. I think it's still a good idea to have a bushing of some sort to reduce shock loads on the mounts and frame.
Old Sep 6, 2012 | 09:49 AM
  #137
very nice, good to know! videos? i plan on doing bushings soon, as right now its metal spacers i made. been sorta lazy
Old Sep 6, 2012 | 09:54 AM
  #138
Nice! thats good to hear. videos? ill run a bushing once i dial in a couple things, right now i just have metal spacers.
Old Sep 7, 2012 | 04:31 AM
  #139
Here's my mounts.
Old Sep 9, 2012 | 10:44 AM
  #140
Man4God's Avatar
Originally Posted by toyminator2000
Here's my mounts.
That's the way I am going to do it when I get around to it. Having to measure all these odd angles and stuff doesn't make sense at all when the stock set up with a simple ear setup will do the job.
What size plate is that? 3/8ths?
Of course, I say this in theory because I still need to actually do the swap.
