Wiring Question
Old Mar 13, 2010 | 10:31 AM
  #41
sam4runner's Avatar
Bringing back the old thread. So i am having trouble figuring out the fuel guage.
Is this something that i have to wire in?
I cant see anywhere on anybody's thread where they say anything about it.
On the EWD's it shows them going to a different plug that i am not working with.
Can anyone help me out here?
Also do i need to wire up anything for the cruise? or is that not messed with?
Thanks
Old Mar 13, 2010 | 12:20 PM
  #42
sam4runner's Avatar
Okay gas gauge works ...just need gas ha ha
Old Mar 13, 2010 | 12:30 PM
  #43
dntsdad's Avatar
LOL..on the gas gauge "not working"
I didnt use any of the cruise wires but i didnt want the cruise installed.
Old Mar 13, 2010 | 09:29 PM
  #44
sam4runner's Avatar
Hey maybe you know dntsdad, what wires did you need for the Tach? I soldered the resistor on but i think i don't have the wires right. On TIS all i can see is a wire that comes from the ignitor to the tach. Is that my wire or what? Any help with this would be great. Thanks again for all your help.
Old Mar 14, 2010 | 07:38 AM
  #45
dntsdad's Avatar
My memory is starting to fade but I am almost positive that is the one that I used.
Black wire (if I remember right) that passes through II3 on the overall diagrams which was the large locking body plug.
Old Mar 16, 2010 | 09:54 PM
  #46
sam4runner's Avatar
Okay everyone, NEW problem ha ha.
So i don't know what is going on but when i mash the gas to the floor the motor bogs down and wont go above 3000 rpm, but if i half throttle, it will climb all the way up and red line.
Any ideas why this is happening? maybe a sensor? MAF?
Thanks everyone
Old Mar 16, 2010 | 09:55 PM
  #47
sam4runner's Avatar
Here is a pic of how it sits now.
Old Mar 17, 2010 | 03:58 AM
  #48
Wavephf's Avatar
I would say either MAF sensor, buy a can of CRC maf sensor cleaner and clean the 2 little wires in the sensor.
Or maybe it is fuel pressure related, Fuel filter plugged, fuel pump cant keep up, fuel line pinched.
Did you run new exhaust? a bad catalytic converter will cause the car to bog at WOT, but the car will normally sound like a giant vacuum cleaner when it bogs.
hope that helps
Old Mar 17, 2010 | 10:55 AM
  #49
sam4runner's Avatar
Is there any way to test a fuel pump? I replaced the filter yesterday and still the same?
I guess i will clean the MAF. Any other ideas?
Old Mar 17, 2010 | 02:56 PM
  #50
sam4runner's Avatar
Cleaned the MAF and still same thing.
It seems like it is choking itself on fuel ... I dunno though...
Any other ideas?
Old Mar 17, 2010 | 08:20 PM
  #51
sam4runner's Avatar
Another quick question? The Diagnostics plug under the hood that is attached to the motor, can i use a scanner to scan that for codes? or does it have to be the OBD2?
I put a new timing belt on the motor, do i need to time it? reset the computer? would that have any effect on what is happening?
Old Mar 18, 2010 | 05:41 AM
  #52
dntsdad's Avatar
obd2 plug is for codes.
If you didnt let the sprockets turn then you shouldn't need to time but probably should check it to make sure.
Old Mar 18, 2010 | 07:26 AM
  #53
yodathespian87's Avatar
I would check the timing likely it is off just a little bit. As DNTSDAD said if the sprocket didn't move I would guess it did just a little.
Old Mar 18, 2010 | 10:27 AM
  #54
sam4runner's Avatar
the top two sprockets did move to the left, but then i moved them back to where they were, all the marks on the belt lined up. could it be that then?
Old Mar 19, 2010 | 05:33 AM
  #55
sam4runner's Avatar
anyone?
the1998sr5
15
Jul 14, 2020 08:35 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
88yodabasket
Jul 13, 2015 01:32 PM
