wanted ( crossover pipe )
Old Feb 23, 2010 | 08:23 AM
mechaniman's Avatar
hey folks,just getting started with my swap. hoping one of you guys has one for sale. let me know . thanks
Old Feb 23, 2010 | 08:29 AM
Tofer's Avatar
Sponsor
stock or already converted?
Old Feb 23, 2010 | 08:30 AM
waskillywabbit's Avatar
Make your own. My bud Jon made one from the stock one in a couple hours and it worked perfectly.
Old Feb 23, 2010 | 08:57 AM
mechaniman's Avatar
conversion cr0ssover pipe
swapping a 3.4 for my 3.slo . just need a conversion crossover pipe. if i have to i'll build one. but would rather buy one that bolts right up
Old Feb 23, 2010 | 09:43 AM
mt_goat's Avatar
I don't know of anyone that sells them ready to bolt up anymore, unless you want it to drop on the passenger side (stock 3.4). You'll probably need to read this: https://www.yotatech.com/forums/f160...r-pipe-138902/
Old Feb 23, 2010 | 10:03 AM
mechaniman's Avatar
crossover pipe
It seems to be the consensus, as far as building a pipe
Old Feb 23, 2010 | 03:26 PM
dntsdad's Avatar
these guys sell them. Nice guys too. they will also convert yours if you send it to them for $150. I think that the core price was $45 or something.
Jason
http://www.toyonlyswaps.com/Home_Page.php
Old Feb 25, 2010 | 12:06 PM
mechaniman's Avatar
Got a crossover pipe comin from TOYONLYSWAPS. $150 bucks and I give them my original 3.4 crossover pipe. thanks guys
Old Feb 25, 2010 | 12:22 PM
mt_goat's Avatar
Great Pics please!
Old Feb 25, 2010 | 04:45 PM
JonnyBoy's Avatar
Those are the guys in Eugene that did mine for me, too. It's working pretty good, the flanges weren't perfect when I installed it, but enough heating and cooling cycles and they're square to the manifolds now.
Old Feb 25, 2010 | 05:35 PM
mechaniman's Avatar
nice, I'm going over there on monday
Old Mar 3, 2010 | 08:14 AM
dem0nk1d's Avatar
good find. i'm sending my pipe out on friday.
Old Mar 3, 2010 | 05:15 PM
mechaniman's Avatar
well, I got my crossover pipe today. looks pretty good, I'll try to post some pics tomorrow.
One thing I realized when getting my crossover pipe was I'm going to have to modify my down pipe. I didn't even think about it but I need to cut the part of the down pipe off the donor vehicle that has the flange and the oxygen sensor port and weld it in to my existing down pipe.I don't know how I overlooked that.
So far [I] have my 3.4l motor on a stand. it had less than a 100k on it. so I replaced t-belt,tensioners,water pump,valve cover gaskets,exaust gasket,intake(i had to for the supercharger),I just dont want to go back there for a while. should be installing the motor next monday.
Old Mar 3, 2010 | 06:09 PM
dem0nk1d's Avatar
sounds like your making head way. i'm taking my time with my build. replacing all major gaskets, etc... etc... once i get my crossover back i should be ready to drop it in.
Old Mar 4, 2010 | 04:15 AM
mt_goat's Avatar
I'd get it ceramic coated if its not already.
Old Mar 4, 2010 | 05:24 AM
dntsdad's Avatar
lets see a picture!!
Old Mar 9, 2010 | 08:37 AM
mechaniman's Avatar
got my crossover
well, got the crossover pipe from (toyonlyswap) thes guys do a pretty good job, my motor is very close to being installed, It has 90k on it so i replaced t-belt, all idler and tensioner pulleys, valve cover gaskets,water pump,intake`gasket( just because i had to install the supercharger) and exaust gaskets,new clutch kit coming today. Im using a 3.0 clutch because thats the fly i have to use. and I went with a t100 dipstick assembly. bolted right up.
anyways here are some pics of the motor. Ill post more after its in my 4runner. and I forgot i need to install the lift kit before i get ahead of myself. thanks for all the help guys. I tried to keep this project under $2000 , but I get an insane discount on parts so I decided to take care of everything before i install the motor. I'm probably close to $2800.
Attached Thumbnails wanted ( crossover pipe )-snb10916.jpg   wanted ( crossover pipe )-snb10917.jpg   wanted ( crossover pipe )-snb10918.jpg
Old Mar 9, 2010 | 08:49 AM
mt_goat's Avatar
Very nice. I like that they kept the factory heat shield, probably don't need ceramic coating with that on there.
Old Mar 9, 2010 | 11:27 AM
dem0nk1d's Avatar
Nice looks good. Did you paint it sliver? Or did they do that? Also I spy a super charger.
Old Mar 9, 2010 | 12:19 PM
UKrunner's Avatar
I went dual exhaust down each side of the transmission and a cross over under the bellhousing. The workmanship is terrible. Something I could knock up myself but still, its done and it sounds rather good.
