More 3.4 questions
Old May 13, 2010 | 09:57 PM
sinneDBTB's Avatar
good to know, anyone know of any sources for 3.4 parts, aside from alpi's?
Old May 14, 2010 | 06:19 PM
ColoradoToy91's Avatar
I have a spare of about everything, what do you need?
Old May 14, 2010 | 11:02 PM
sinneDBTB's Avatar
m/t ecu and harness, evap and power steering
Old May 22, 2010 | 08:42 PM
sinneDBTB's Avatar
turns out alpis is the best source for the parts i need... go figure, the last place i think to look. anyways, my 97 auto ecu and harness that dont match are up for sale to anyone interested.
Old May 31, 2010 | 09:01 PM
  #25
sinneDBTB's Avatar
Originally Posted by RobD
I'm not running it at all. I'm sure I have some code or another, but my CEL isn't hooked up, either.
I've never used the cel to read codes or whatever. i took the bulb out cuz i couldnt figure out how to get it to go off when i had to do a V.I.
How does yours run without it wired?
Old May 31, 2010 | 09:04 PM
  #26
sinneDBTB's Avatar
Originally Posted by NIGHTCRAWLER541
Some early years have a 4 wire TPS. EVAP sensors differ slightly on early 96 models. Try to get the 3 evap sensors with your harness and ecu. If you plan on running your CEL.
so i can get away without the evap if i dont use the CEL?
Old Jun 1, 2010 | 04:49 PM
  #27
RobD's Avatar
My CEL isn't wired. Runs fine.
Old Jul 2, 2010 | 06:23 PM
  #28
sinneDBTB's Avatar
new question, does a 3.4's rad fit in place of the 3.0's?
Old Jul 2, 2010 | 07:06 PM
  #29
sinneDBTB's Avatar
bump?
Old Jul 2, 2010 | 07:50 PM
  #30
RobD's Avatar
No. Use the 3.0 rad. Works just fine.
Old Jul 2, 2010 | 08:15 PM
  #31
sinneDBTB's Avatar
ok thanks, i thought i may be able to save some hassle with the plumbing.
Old Jul 3, 2010 | 10:34 AM
  #32
dntsdad's Avatar
Also, you will use the stock 3.0 thermostat housing as well. This way you can use an off the shelf radiator hose, but it will require a little shortening of the end going to the radiator to clear the alt belt
Old Jul 3, 2010 | 12:53 PM
  #33
UKrunner's Avatar
I used 3.0 rad and stock 3.4 tstat housing. There are carquest hose numbers around here that get you the right hoses. Either lower or upper needs about 4 inches cut off one end though. Simple really.
Edit, I suggest changing the hoses to the oil cooler on the side of the block. Mine where rotted and heat damaged. Lasted about 1000 miles then burst. Not the easiest of jobs replacing them with the engine in.
Old Jul 3, 2010 | 11:31 PM
  #34
RobD's Avatar
I used both the upper and lower 3.4 hoses with my stock 3.0 radiator. Had to trim the lower one a bit to get it to fit, but otherwise it fit fine.
Old Aug 29, 2010 | 08:36 AM
  #35
sinneDBTB's Avatar
how did you set that up? just plug the lines? pics?
Old Aug 29, 2010 | 04:10 PM
  #36
sinneDBTB's Avatar
I got the EVAP figured out, just followed what elvota did in his swap.
Now I have read a lot about people having trouble with the ADD system, what's that all about?
Also I used the Power steering line from the 3.0 but I've noticed that the 3.4 has vacuum lines in it, what are those for? do i need them?
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
coleypull15
Nov 3, 2015 07:41 AM
AndYota
Aug 10, 2015 09:19 AM
TJWilly
Jul 31, 2015 02:05 PM
Cplmike
Jul 8, 2015 08:47 PM
