Conversion Wiring
Old Apr 12, 2009 | 04:02 PM
  #61
TMZ's Avatar
TMZ
This harness lets you plug the 3.4 engine harness directly into the 3.0 or 22r, re body harness.
Old Apr 12, 2009 | 05:25 PM
  #62
Spinnbait's Avatar
pm'ed you regarding domain name composition...
Old Apr 13, 2009 | 07:03 AM
  #63
dem0nk1d's Avatar
what sensors need to be changed on the engines side of things? I know the 3.4 runs a map, and other things. will this harness work for California type trucks wanting to be bar'd by the ref?
Also i take it we will have to use a specf year ecu for the harness correct.
Old Apr 13, 2009 | 07:59 AM
  #64
olharleyman's Avatar
Did you ever get the ecu #'s I sent you for mine? I will be happy to send them again if not
Old Apr 13, 2009 | 08:14 AM
  #65
TMZ's Avatar
TMZ
No sensor changes, use the ones that came with the donor engine. You will need a Cal spec ecu if you want to pass ref. I will need to know the ecu part #.
olharleyman pm'ed you.
Old Apr 13, 2009 | 01:32 PM
  #66
dem0nk1d's Avatar
well i would like to see a detailed write up on how to use the harness.
Old Apr 14, 2009 | 03:27 AM
  #67
TMZ's Avatar
TMZ
Pretty much just plug it in between the 3.4 engine harness and your trucks dash harness.
Old Apr 16, 2009 | 10:18 AM
  #68
MaXXis85's Avatar
What is your going cost?
Old Apr 17, 2009 | 08:15 AM
  #69
Blown2001Runner's Avatar
tmz, goog luck on your website!!
Do you know of any good sources for 5vz's. Toyota are few and far between in my area it seems. Also the local junkyards dont want to work with someone like myself, who cannot generate a list of all the parts i need. it would also be helpful to take the donar apart myself so i can see how it all goes together, rather than have someone just rip my apart.
Old Apr 17, 2009 | 03:03 PM
  #70
TMZ's Avatar
TMZ
am still working on pricing. I do not need your harness to do this unless your ECU does not match your harness and you need it repinned. I am working on a stand alone harness that can be used in a buggy or race truck. I will also be doing harnesses for 2rz, 3rz, and Lexus V8. Complete E-Locker harness from switch to locker will be available soon
3.4 Conversion Harness $350.
Convert Auto to Manual + $50.
Repin Harness + $100 I will supply the needed connectors
URD Rear O2 sim + $100 I will supply the sim
Old Apr 17, 2009 | 06:56 PM
  #71
now i am defintally in the market for an e-locker harness right now. I assume it will use the oem switch?
Now to only find a e-locker diff.
keep up the good work!!
Old Apr 21, 2009 | 05:24 PM
  #72
TMZ's Avatar
TMZ
LukaDuke15's dash harness for his race truck.
Old Apr 21, 2009 | 07:35 PM
  #73
Spinnbait's Avatar
Nice work!
Old Apr 22, 2009 | 03:03 PM
  #74
syber_kowboy's Avatar
TMZ the stuff you are producing is really nice man. Clean and complete. Congrats!!
Old Apr 22, 2009 | 05:27 PM
  #75
TMZ's Avatar
TMZ
Thanks guys.
Old Apr 24, 2009 | 06:15 PM
  #76
RMA's Avatar
RMA
the wiring you are doing looks really good ,very clean.
Any updates on Cadi_daddy's harness.
Old Apr 27, 2009 | 09:47 AM
  #77
TMZ's Avatar
TMZ
The first Photo of the completed harness is Cadi_daddy's. His harness is in transit to him.
Old Apr 27, 2009 | 05:10 PM
  #78
TMZ, the picture you put into post #58 has a little blue wire in it, almost looks like phone cable...what is that??
cheers
Old Apr 27, 2009 | 06:50 PM
  #79
cadi_daddy's Avatar
its for a house phone, duh. im not really into having a cell phone.
just playing, i have no idea what it is, but it probably is important if Tim has it wired in there.
jason
Old Apr 27, 2009 | 06:57 PM
  #80
haha....a house phone....
