Bend's 3.4 to 88 5speed 4runner
Old Jan 22, 2012 | 11:21 PM
bend's Avatar
Oh and thank you Vasin. I didnt think to look at my ewds.
Old Jan 22, 2012 | 11:36 PM
bend's Avatar
I think this answers my starter relay question
https://www.yotatech.com/forums/f160...4-swap-237324/
https://www.yotatech.com/forums/f160...wiring-155380/
Old Jan 27, 2012 | 09:23 PM
bend's Avatar
Well I've just been tying up some loose ends while I wait for a fuel line to come in. I have to buy a 14mm male fitting and make an adapter for the two female ends. All my wiring is done. Well besides my 4wd and ac. I can manage without those for a bit till I get them figured out. I really dont want to cut my alt bracket but it simply wont fit. Anybody got suggestions?
Old Jan 28, 2012 | 06:09 AM
theMonch's Avatar
Go for the cut alt bracket, it is actually pretty cheap to replace if you ever want to put the motor in something else.
As for the A/C question you PM'ed me on, yes I did get it running. Ironically, i had to do no wiring to do so. I was left with two wires from the 3.0 AC amplifier and 2 wires from the 3.4 ecu that I didn't have to hook up. I charged up the system and it just worked. I cannot confirm how well, of if the lack of communication with the ECU would have any long term effects, since the charge leaked out overnight (sorry ozone layer). It leaked from the R134 conversion nipple.
Old Feb 16, 2012 | 07:05 PM
  #25
bend's Avatar
Ah I am almost done with the build. I'm just waiting on a custom ss line. I got it today but it had two male fittings instead of two female fittings. Pretty ticked off since I thought I would be done today.
Old Feb 27, 2012 | 10:46 PM
  #26
bend's Avatar
Bleh. Finally got my clutch hose in today. Got that installed. I went to plug in the ecm but some of my wire plugs are too narrow. I have the correct plugs for the ecm but the actual wire plugs are too narrow for the pins. Anyone else run into that? I havent had a chance to do an in depth search since it is 2am and I have school tomorrow. I think I read people use their old 3.0 plugs but my 3.0 plugs dont resemble my 3.4 plugs. Hope this makes sense. i will probably end up junkyarding it.
Old Feb 27, 2012 | 10:57 PM
  #27
bend's Avatar
Actually just tried the 3.0 plugs and they fit. I'll solder them tomorrow and hopefully have a start up video.
Old Feb 28, 2012 | 09:04 PM
  #28
bend's Avatar
Tried starting it tonight but it just clicked. I am going to get my battery charged tomorrow since it was at 12.30 volts. Hopefully it is the battery. I have the starter wired correctly.
Old Mar 2, 2012 | 03:28 PM
  #29
bend's Avatar
Just bought a redtop for 130 bucks from advance auto online. They have some good deals going on this weekend
35% off friday only - FRIDAY32
30% off saturday only- SATURDAY33
25% off sunday only- SUNDAY34
Old Mar 2, 2012 | 05:17 PM
  #30
vasinvictor's Avatar
Cool man thanks for the heads us. I need some CV axles. Did you ever get yours to crank?
Old Mar 2, 2012 | 05:29 PM
  #31
bend's Avatar
No I didn't get it to crank. I didnt get it charged though but I did try to jump it. I dont think I gave it enough time to charge though. I need to find some free time and see what I can do. I am going to go through and clean all of my grounds.
Old Apr 27, 2012 | 07:37 AM
  #32
bend's Avatar
So I finally it got it running a week or so ago. It is hard finding time to work on it with school. I'm sure school is nothing compared to a 9-5 and kids. Anyhoot It is missing pretty bad until it warms up. It also dies after i start it for the first time. If i crank it again it will run. I am going to pull codes tonight or tomorrrow. One of my grounds was loose so i'm hoping that fixed it.
I plan on updating this post with various lessons i have learned.
Issues:
https://www.yotatech.com/forums/f160...-relay-250840/
Good Vacuum pictures
https://www.yotatech.com/forums/f116...k#post51402939
Things I have learned:
Don't rush
Label the tranny plugs on your donor
If you buy a totaled vehicle, it will take a long time to successfully part it out. Most places wont let you have a totaled vehicle in your front yard.
banjo bolts dont have to have their holes line up
Use an engine load leveler when pullling/putting the engine in.
Cut off the heads of some tranny bolts and use them as a guide. Cut a notch into them so you can screw them out.
The components section of the ewd is a huge help in identifying what tranny plugs you need. I used d3 for my 4wd detection
I would like to post up a pic of my vac lines
AC works. Didnt have to wire anything up or change amps. I just changed the top plate on the compressor. Cost me 200 bucks to charge it. I probably wouldnt get it charged if I had the choice. Doesnt work like new.
Make a bag for bolts you are not going to use again or they came off of your donor. I had so many I tossed off to the side and I couldnt remember if i just set it down or i tossed it earlier.
Dont use plastic hose couplings. They melt. Find some metal ones.
Replace all of your heater hoses. You will feel like an idiot when one blows and you overheat.
Replace your rear main seal. Build your 3.4 to last.
make the chain on the hoist as short as possible so your engine clears your grill.
n5-12 gets split to +b ecu terminal and ii3-16
https://www.yotatech.com/forums/f116...er-way-251920/
Old May 28, 2012 | 08:14 PM
  #33
bend's Avatar
I put in marlin's shifter seat and bushing kit in. I can definitely tell a difference. I'm not sure I like it though. I used to be able to just push the shifter forward and it would slide into 3rd from 2nd. Now I have to push it to the right a little. I'm sure I will get used to it and like it. The old seat and bushing werent in terrible shape after 260k but they definitely needed to be replaced. I plan on getting some headlight conversions, ultra-gauge, lock and ignition cylinders, various trim pieces, head unit, speakers, and battery box once I get paid this weekend. Should be fun.
Old Jun 26, 2012 | 08:37 PM
  #34
bend's Avatar
I think I have an external hg leak. This sucks. I feel hopeless. I'll know for sure this weekend
Old Jun 26, 2012 | 09:58 PM
  #35
vital22re's Avatar
totally a bro
That was a common problem with the older 95-96 3.4's. As far as A/C, you should only need to connect the (ACT) wire to the ac system. the other a/c wire from the ecu i believe controlls the idle up as I used the 3.4 amplifier and mine idles up however several i've done use the 3.0 amp and a/c kicks on but does not idle up as well as it should.
You leave the starter relay and the ribbed box is the resistor pack for the injectors and are not needed.
Old Jun 27, 2012 | 07:19 AM
  #36
anthony1's Avatar
Where does the HG leaks exactly? I have a 95/96 3.4 also. It only had 67K on it when it was pulled out of a crashed T100. What's the millage of your engine?
Old Jun 27, 2012 | 08:45 AM
  #37
SacRunner's Avatar
I just found out I have a bad head gasket on my 96 4Runner engine with 125,000 miles (coolant in the cylinder), so I'll be tearing into mine this weekend too.
I guess Toyota was still figuring out how to make a durable, non-asbestos, head gasket to work with the cast iron block and aluminum heads (the same or similar issue that plagued the 3.0...or at least part of the 3.0's problems) during the early years of the 5VZ, I'm not sure when they found the winning combination.
So far, the best/only 5VZ head gasket writeups I've found...
http://www.ultimateyota.com/index.ph...6&topic=2241.0
http://www.ultimateyota.com/index.ph...6&topic=7462.0
And Toyota has a couple different head gasket kits, one is just a gasket kit (head gaskets, plenum gaskets, intake manifold gaskets) for about $150 or a complete top-end rebuild kit (everything you should need just without any new hardware (nuts/bolts)) for about $450. The head bolts supposedly are TTY (torque to yield) and should only be used once (at least that's what I'm starting to piece together); those suckers are $9 each and you'll need 16 of them.
Just a little heads up into what you could be encountering. Good luck.
Old Jun 27, 2012 | 08:50 AM
  #38
bend's Avatar
Rear passenger side. I think. I'm taking it into a shop to make sure. It has 130k on it
Thanks I genuinely appreciate it. I was wondering how much this is going to cost me. Not too excited about it.
Old Jul 15, 2012 | 01:05 PM
  #39
bend's Avatar
Crisis averted. Turns out it was just a freeze plug.
Old Jul 15, 2012 | 06:23 PM
  #40
vital22re's Avatar
totally a bro
helped a friend tear apart a 96 runner today. Headgasket failed passenger side at cylinder 1.
