AW4 to a 3.4?
yes and its easier than you think. the aw4 and a340 are the same trans. swap bellhousing, oil pump, torque convertor, and valve body from an a340 to the aw4 and your good to go. google search aw4 a340 swapability.
you might not have to go that far if the valve bodies are close enough just the bell and tq convertor. yota motors in a jeep would be cool or if your looking for an atlas case to bolt up this would be the best option
there is a guy who put a twin turbo 2jz in a cherokee and thats what he did to build a 4wd trans out of the toyota a340e 2wd tranny that came with the swap.
what are your goals? I can help more if you can be more specific.
Thanks! Building a buggy and want to use the 3.4 for a motor and need the AW4 to use an Atlas. Any info would be great. Do I need to swap the input shaft?
Steven.m.paulk
Jun 7, 2020 10:45 AM
primordialbeast117
Dec 19, 2015 12:23 PM
