Anthony's 3.4 swap
Old Aug 18, 2011 | 08:20 PM
  #41
ChefYota4x4's Avatar
Well, please let me know if I can help with that, Anthony.... I can't promise on short notice with my life, lol... But I WILL TRY! I've helped quite a few L.A. yotatechies, WITH PLEASURE! lol... But you're REALLY local... so it's not any trouble, providing I can get away. If you'd like to have a second set of hands... just call first, ...can't hurt to ask me, right? lol.
Best wishes, either way, Anthony! Blessya!
Old Aug 20, 2011 | 12:05 AM
  #42
anthony1's Avatar
I'm doing ok with the project. I almost have the engine physically in the truck.
The duct tape is there to hold the plywood to protect the condenser.
I forgot to cut off or remove the old exhaust so it's not sitting right. I'll cut some off tomorrow. It's a challenge trying to line up the transmission input shaft with the pilot baring with bulky engine. I'm hoping that if I lined up the bolt holes that the rest will lined up ok.
Old Aug 20, 2011 | 12:14 AM
  #43
Let me know; I might be able to help tomorrow, Anthony. If you need me of course, lol.
Old Aug 20, 2011 | 12:17 AM
  #44
anthony1's Avatar
I"m gonna try to get the engine in correctly tomorrow. I'm still playing chauffeur to one of my kids who has clarinet lesson and wheel ceramic class. I wonder how early can I use a wheel cutter....
Old Aug 20, 2011 | 02:48 PM
  #45
Hahahaha.... Wheel cutter? Meh... 7:30AM is the LAW, man! KILL IT! hahaha.
Blessya'&'Yers!
Old Aug 20, 2011 | 03:50 PM
  #46
anthony1's Avatar
Engine is in.
Old Aug 20, 2011 | 03:52 PM
  #47
anthony1's Avatar
Since I have the 96 T100. I think I just comply to the smog stuff for that year...right?
Toyota still use the chacoal canister like my 95.
Old Aug 20, 2011 | 04:48 PM
  #48
AWESOME! Hey, you have to give me a ride in that thing when you're ready, ok? BTW, ... I meant it, man... I would love to help if you need it and I can make it out... Just let me know, ok?
I know nothing about requirements, etc., ... but I'm sure you'll get it just right. LOOKS SO CLEAN, ANTHONY!
Old Aug 20, 2011 | 08:44 PM
  #49
anthony1's Avatar
I learned a few things ....
I tried using 3.4 starter but it doesn't work. The F150 man
trans already has threads on the bell housing. The 3.4 starter has threads on both holes.
I also switched the alternater belt and power steering belt so the alternator doesn't touch the steering shaft plastic cover.
Old Aug 20, 2011 | 08:46 PM
  #50
Tight fit, eh?
Old Aug 20, 2011 | 08:54 PM
  #51
anthony1's Avatar
wow! that was fast. are you stalking this thread? .....LOL.
Old Aug 20, 2011 | 09:18 PM
  #52
I'M STALKING THEM ALLLLLLLL, MUAHAHAHAHAHAHA! hahaha.
JK, ... I just wanted to let you know that I would gladly help, Anthony... Oh, and I promise, I wasn't trying to be pushy! lol. I've had multiple opportunities to check in today....
PS> at least I'm posting, right? lol. I mean, this is a very desired swap.... I'm really shocked, to be honest, that more haven't chimed in! lol. But then, you're fast, so I guess that's part of it.
I bet you can't wait to fire it up and roll to the mountains with that sweet trailer of yours! eh? lol.
Old Aug 21, 2011 | 03:57 PM
  #53
theMonch's Avatar
Nope. If your using the 3.4 flywheel you use the 3.4 starter. You simply drill out the starter thread holes so the bolts can go through to the bellhousing. This is so you can use the entire 3.4 clutch setup except the TO bearing which is from the 3.0. I am assuming that you already have that setup in there?
Old Aug 21, 2011 | 07:30 PM
  #54
anthony1's Avatar
Actually, I resurfaced the 3.0 flywheel and using Luk clutch kit. I'm using 3.4 pilot bearing though...which seems to be the same size as the 3.0.
I guess it's good that I didn't know about drilling out the 3.4 starter....
Thanks.
Old Aug 21, 2011 | 09:25 PM
  #55
vital22re's Avatar
totally a bro
Thanks.
if keeping the 3.0 flywheel use the 3.0 clutch disk, pressure plate, starter, throw out.
I believe the pilot is the same between the 3.0 and 3.4.
Old Aug 22, 2011 | 06:38 AM
  #56
anthony1's Avatar
great. that's one hurdle down...I also noticed I don't have EGR system on this one. There's a plug on the driver side of the exhaust manifold for it.
Question..There's two little tube for the coolant that goes towards the rear of the vehicle...what' is that for? It's hooked up through a T for the heater.
Nevermind, I think I have the optional rear heaters so I think that's where it goes.
Old Aug 27, 2011 | 02:22 PM
  #57
anthony1's Avatar
Hmmm... my 95 runner alternator plug is the same as 96 T100 3.4.......kewl!
I wonder what else are the same.....
Old Sep 6, 2011 | 04:21 PM
  #58
anthony1's Avatar
just an update....
radiator, and fan is installed
Got the 10K ohm soldered on the tachometer pcb.
made a 4 wire cable harness for OBDII connector.
made a starter wire to be fed into the wireloom.
Old Sep 7, 2011 | 09:42 PM
  #59
Sweet, ..... when you gonna swing by and take me for a cruise in that MO-POWA beast? lol.
Old Sep 7, 2011 | 09:52 PM
  #60
anthony1's Avatar
haha. I'm down to wiring now.
I post on another thread about using auto ECU instead of the manual one that I got for 98 when my engine is from 96.
I'm also dealing with my Trans on the supra now. just happened this eve. sunk in and didn't come back up. I pulled it up after pulling over. It became stiff after that. I think the seal on either the slave or the master cylinder is bad. I think I'm gonna replace them to see if it fixed. If not, it's the pin in the fork that's loose. I can't tell yet. I'll deal with it on Friday when I take the day off. I'm getting a ride from a co worker that lives in Lomita tomorrow.
I'm getting a new fridge too...the old one is not cold anymore. I tried cleaning the condeser with no luck....14 yr old fridge.
We're down to one car now. Tomorrow, my kids starts school too.
sigh....just one thing after another....How much more can be pile on here.....
