3.4L swap hood scoop
Old Jun 5, 2009 | 11:14 PM
zach88's Avatar
My 3.slow recently decided to blow the head gasket and crack the heads, so i am going to do a 3.4l swap.
i think i might have an engine lined up already
What i was wondering is this. I know you need at least a 2" body lift to clear it, and i have a 3" that i would really like to take off... some trails are pretty scary with my 7" of lift haha plus i like the look of a 4" suspension with 35's
how hard would it be to make a hood scoop? how much do you guys think one would cost?
any thoughts or input would be great
and yes, i know how to use the search button. there wasnt much on this at all so dont tell me to just search
Old Jun 5, 2009 | 11:48 PM
Tofer's Avatar
Sponsor
this was my $8 fix for not having a body lift... its kidna ghetto but it works for now until i make a hood scoop.
Old Jun 6, 2009 | 06:01 AM
RobD's Avatar
This is the one I'm running after my swap. Personally, I would have liked something smaller, but it does blend in well (it comes molded in black and my hood is dark gray).
http://www.lundinternational.com/lun...on__truck.aspx
There are a ton of choices on eBay.
Old Jun 6, 2009 | 07:10 AM
poolskaterpt's Avatar
I ave a similar setup as tofer- but much less of a standoff in- about 3/8". littl trick, ground down the front of the intake mani a hair- just on the front edge because that is where the interference fit is. I didnt want to go hood scoop because its non functional and i would just end up with more debri in the engine bay. If you want the look of a hood scoop just slap one on and do a simple cut out for clearance- doesnt all that much matter cause it isnt functional anyway. I'd go with a six pack scoop from a 70 plymouth GTX (im a mopar street guy)- while you're at it, put the 440 from one in there!! jk. Good luck.
Old Jun 6, 2009 | 09:20 AM
cadman's Avatar
My hood clears with a 1" body lift. A couple spots rub on the insulator beneath the hood, but when I replace it with a new one I'll cut windows at those rub points.
Old Jun 8, 2009 | 06:34 AM
yodathespian87's Avatar
Here is what I'm getting for mine.
http://store.summitracing.com/partde...art=SUM-470700
Old Jun 8, 2009 | 09:02 PM
RobD's Avatar
http://www.jegs.com/p/Harwood/Harwoo...46480/10002/-1
Old Jun 8, 2009 | 09:54 PM
904_runner's Avatar
I don't have a body lift or hood scoop
I have a couple dents in my hood and it clears good! lol ill have to cut off the bracing though sicne its rubbing a little.
Old Jun 10, 2009 | 08:56 PM
JonnyBoy's Avatar
Nice Rob, I think I'm going that route! 904, did you reuse the old motor mounts from your 3.0, or didja buy brand new ones?
Old Jun 11, 2009 | 05:00 AM
I used my old ones, the only reason I would see replacing them is if they are worn out.
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
1996Taco
Jul 20, 2015 12:02 AM
taller1
Jul 16, 2015 03:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
