3.4 swap started
Old Mar 5, 2007 | 10:13 AM
  #441
mt_goat's Avatar
Originally Posted by JHRRLD
Dale I might be able to lend you some assistance in the next few weeks, we are diving into tuning mine here soon after the VB is done.
That would be great Josh, thanks.
Old Mar 5, 2007 | 10:21 AM
  #442
mastacox's Avatar
Originally Posted by mt_goat
Are you tuning by yourself or is someone helping you? Do you remember if you've gone much below 8.8 anywhere on the fuel map #s?
FWIR, none of the numbers in my Fuel Map are quite that low... but I might have some 9.3's in some spots near idle. I don't have "my" laptop back until next weekend, I'll check the maps for you then.
While we're asking about maps, what kind of timing retard are you using in yours? I had to push mine up to 6.5 deg. in some spots to completely eliminate ping...
Old Mar 5, 2007 | 10:32 AM
  #443
JHRRLD's Avatar
Mine pings badly at low rpm's and even worse with the deck plate off. I'm pretty sure I'm really going to have to mess with the timing part of the map.
Old Mar 5, 2007 | 10:53 AM
  #444
mt_goat's Avatar
Ok thanks Brian. I haven't touched my timing map yet, so its still just as Gadget send it. So far I've had very little pinging.
Old Mar 5, 2007 | 10:56 AM
  #445
mastacox's Avatar
It's not all that hard to do, especially if you can find a nice hill to induce ping on... Make sure and tune with the deckplate out, so you're tuning for the highest flow available.
Lucky you! My timing map wasn't even close, I had to stretch the area it covered and double the retard in some areas. I wonder if it's an altitude thing...
Old Mar 5, 2007 | 11:18 AM
  #446
mt_goat's Avatar
Humm.... I thought the altitude was suppost to help Maybe its all the up hill climbing you have to do?
Yes I was very lucky, Gadget's preloaded maps seem to be amazingly close for my truck. If it wasn't for going a little too rich in open loop I'd probably leave it alone.
The couple times I've had some pinging was right after I made a change to the fuel map but then it seems like the ECU makes corrections and it stopped.
Old Mar 26, 2007 | 09:22 PM
  #447
displacedAlaskan's Avatar
I like the tupperware container lid idea. It sounds pretty innovative to me. Think outside the box innovative. Your woman might not think sharing her tupperware lid with you would be such a great idea though.
Just a thought.....
I'm curious about whether swapping out an A340H auto transmission for a rebuilt manual transmission would work, and if so is it cost efficient to just put in a manual transmission instead of replacing the A340H that is ready to die any time? What are you guys' thoughts?
Old Mar 27, 2007 | 04:09 AM
  #448
mt_goat's Avatar
Actually the 1 lb Vihta Vuori gun powder container is what matched prefect. See post #30: https://www.yotatech.com/forums/show...5&postcount=30
Sorry I don't know anything about the manual tranny swap, except its easier than the auto tranny swap. There are tons of threads out there on the manual 3.4 swap because that was all anyone did did for a long time. Until Team Shiftpoint did it with his autos and Mike @ ORS developed a kit for the auto and let everyone know it was possible.
To update with the FTC tuning, I just ordered this driver-visual knock warning system:
http://www.turboxs.com/more_info.php?ID=212
Here's the thread where I heard about it on CT and Gadget recommends it:
http://www.customtacos.com/forum/showthread.php?t=86076
Old Mar 27, 2007 | 06:09 AM
  #449
mastacox's Avatar
Tuning experiences deleted, moved HERE
Old Mar 27, 2007 | 06:56 AM
  #450
mt_goat's Avatar
Hey thanks Brian for the tips and figures. The last paragraph one thing really jumps out as WEIRD. Your A/F is 12:1 while engine braking? Mine is more like 20:1 or even off the readable scale. I'd look into that, who wants to waste fuel while decelerating? Should'nt you be able to do a free air calabration during a long deceleration?
Does your ECU go into open loop very easy? Mine is making the switch to open loop at what seems like about half throttle sometimes, I thought it was suppost to only do that at about 80% throttle. Worst thing about that is I have a big jump to a rich mixture when it makes the switch to open loop (generally around 10:1-11:1)
I finally tried my new (to me) laptop that I got for $50 and I can report it works dandy at running both R4 and OBDII software at the same time. (Thanks Josh) Windows XP rocks. I'd now recommend NOT using any laptop with windows 98 2nd ed for tuning.
My water temps this week (70-75 deg days) have been running about 185-190 max so that's encouraging. I'm wondering now if I didn't have an air bubble in the system before.
Old Mar 27, 2007 | 07:07 AM
  #451
mt_goat's Avatar
EDIT: On another note, my Walbro fuel pump has been getting louder for some reason. After driving for several hours it will begin making a pretty loud whistling/whining noise. At first I thought it might be some kind of vacuum leak but sure enough it's coming from the gas tank. It's only been installed for 6 months, it had better not be going bad on me. If it is, it's easy enough to replace but still... Maybe I'll bump up to a 255lph if I need to replace it?
Hummm... sorry to hear that. I haven't heard of any failures with them yet, have you? My 95 Taurus makes quite a whine whenever it gets below about 1/2 tank but it still runs fine. I just use the whine as a fillup reminder now. Can you hear it all the time or just idling?
Old Mar 27, 2007 | 10:14 PM
  #452
Redeyejedi's Avatar
damn fine write up, supa sweet build, and mad props to you guys helpn out. new member here but been readn up for months. excellent stuff mt goat. as far as your temps and fan issues...what goes in must go out(so to speak) is air having problems leaving your rad....essentially casuing a 'bottleneck' of flowing air? i dunno, just a thought and wanted to see if i could help on a badass thread.....prolly THE badass thread for a while to come.
oh and speakn of IC's mitsu evo's have IC sprayers that spray either manually or intermitantly a mist-O-h2o on dat der IC for colder induction....another after thought...but might need a heat disipatn paint/protectant on fins....i dunno....
Old Mar 28, 2007 | 04:13 AM
  #453
mt_goat's Avatar
Originally Posted by Redeyejedi
... excellent stuff mt goat. as far as your temps and fan issues...what goes in must go out(so to speak) is air having problems leaving your rad....essentially casuing a 'bottleneck' of flowing air?
Thanks for the kind words, I think I pretty much took care of the airflow out of the rad when I did this to the fan shroud:
See post #413 here:
https://www.yotatech.com/forums/show...&postcount=413
Old Apr 30, 2007 | 09:40 AM
  #454
mt_goat's Avatar
Originally Posted by suprathepeg
Dude I've been researching the toyota cooling systems on the 3.0 and 3.4. From what I've found it seems the one area Toyota left for expansion is t-stat. Not opening temp but flow at temp. I looked at the stock stat for the 3.4 and it is pretty big and yet TRD made a larger one for FI applications on the 3.4. I would see if you can compare the one you baught and the one from the Dealership.
Ok, I'm ready to try that TRD t-stat now. Yesterday we got a fairly warm day (83 F) and I took the wife for a cruise out of town. Going down the interstate with the cruise control set on 75mph, AC on all the way, stereo on etc... the coolant temps slowly climbed up to about 210-212 and mostly stayed there with the highest I saw 216 (all measured with the OBDII scanner). The factory temp gauge stayed pegged in the middle the whole time. Fan was running on high all the time at highway speeds. The boost would kick up to around 3-5 psi on some of the hills and the A/F ratio varied from 14.7 with no boost, to about 12 with 5 psi (with a nice smooth transition BTW ) EGTs were normal (around 1250F-1350F max), tranny temps 170-180F (measured right before the radiator cooler)
I ordered the TRD 160 deg t-stat this morning from Roger @ Bob Bridge Toyota ($36) https://www.1sttoyotaparts.com/partscat.html
For review, I currently have:
*URD (Napa) 170 deg t-sat
*New 3vz-e aftermarket radiator
*Taurus fan controlled by a DCC variable speed controller, wire run to the high speed side of 2-speed Taurus fan.
*I did park on a steep slope with the front end higher to get the air out
*Running water wetter with a 50-50 mix of coolant/distilled water
*Arrowdynamics of a brick and spinning 33" mud tires
While disapponted with the water temps, it sure was nice to cruise dowm the highway at 75mph without dropping out of overdrive for hills or headwinds.
Old Apr 30, 2007 | 10:22 AM
  #455
TNRabbit's Avatar
Geez, mt goat; that was a d@mn fine idea with your fan shroud!! I love it.
Old May 1, 2007 | 06:33 AM
  #456
mt_goat's Avatar
Well thanks, too bad it didn't work a little better. If the TRD t-stat doesn't do the trick, I may go back and try the stock fan.
Old May 1, 2007 | 08:44 AM
  #457
mastacox's Avatar
Hmm, I feel like we went over this before in some other dimension...
Old May 1, 2007 | 05:23 PM
  #458
mt_goat's Avatar
Is that like deja vu all over again?
Old May 2, 2007 | 04:37 PM
  #459
toy power's Avatar
so did you get a chance to install that thermostat? i am pretty curious what is wrong. i will say i think it is something else other than the thermostat or fan. going 75 the rad should be getting more than enough air; and for temps to be that far away from the thermostat's rating, something pretty significant must be wrong. i take it the motor itself is solid? maybe it is something as simple as a crossed hose connection, or even better just a faulty thermostat. let us know and good luck
Old May 2, 2007 | 07:04 PM
  #460
mt_goat's Avatar
Not yet, it's on order. Yeah the motor only has about 28,000 miles on it. What do you mean by a crossed hose connection?
