3.4 swap started
Old Oct 24, 2006 | 11:47 AM
  #361
89934runr's Avatar
Dale-
are you using the stock sensor to check temps (via a scan tool)?
Old Oct 24, 2006 | 11:48 AM
  #362
mastacox's Avatar
Originally Posted by mt_goat
I don't know, do you think 193 is too hot? May wait and see what some of you other guys are getting for temps. I'm not pinging any that I can tell. I'm tempted to put the stock fan on and try that. Also tempted to cut the grill open some.
Well, 193 isn't SUPER hot, but the worry is can your cooling system keep up under a medium to heavy load... I'll let you know what my temps turn out to be.
Trying the stock fan might not be a bad idea (if you have a shroud that will work with it) but don't bother cutting your grill, it's the TJM that's doing most of the blocking IMO.
  #363
mt_goat's Avatar
Originally Posted by 89934runr
Dale-
Yes, the OBD2 reader.
Old Oct 24, 2006 | 12:00 PM
  #364
mt_goat's Avatar
Yeah really it's in the summer when the temps are 100+ and the AC is running full blast and the truck is loaded down with gear going up hill into the wind and the closest help is 100 miles away at Clines Corner, that I'm worried about. Can I call you for help Brian?
About half of the radiator is behind the bumper and half is above it. The half that is above it is mostly just blocked by the plastic grill. I don't really like that chrome colored plastic crap anyway.
Old Oct 24, 2006 | 12:35 PM
  #365
mastacox's Avatar
Yikes, you could call I suppose but Oklahoma's a long way from New Mexico
You might consider going to a tube bumper... if only because it will give you some air flow thru that other half of your radiator. But, before you do that you really need to just take the TJM off and see if that alleviates your difficulties.
If you had a truck, I'd almost tell you to consider a remote radiator right about now But, remote radiators don't really work on 4Runners...
Old Oct 24, 2006 | 02:47 PM
  #366
AH64ID's Avatar
193 isnt too hot, but your fan running at fwy speeds still isnt right. Yes it fixed the problem, but I see it as a bandaid.
I would like to see the results of a test drive on the fwy with no fan/shroud.. but could be a dangerous test, thou I think you would be fine...
Instead of cutting off the bottom you could drill some 1-2" airflow holes... The more I think about it the more I think Brian is right... the shroud is creating an air dam... If you had the stock fan it would still slowly spin with the engine rpm drawing air thru.
For reference my dad has elec fans on his 454 suburban. Towing on flat ground the fans are off, only when he hits big hill do the fans kick on. His fan used to work more, but had a clogged radiator. New radiator and his fans rarely work around town, never on the fwy. Granted its a HUGE radiator, its also a HUGE motor and HEAVY rig.
Old Oct 24, 2006 | 03:33 PM
  #367
mastacox's Avatar
I don't really think his shroud is creating the problem, I think the TJM is blocking too much of the radiator, and at highway speeds the fan is forced to turn on in order to get enough air to pass thru the radiator.
Old Oct 24, 2006 | 03:44 PM
  #368
AH64ID's Avatar
Arent there many other rigs out there with TJM and ARB bumpers, without heat issues on S/C 3.4 motors? I dont know about the TJM personally but my ARB doesnt block all that much flow. It even has cutouts and deflecters. It was hard to tell from his photo, but it looks to be similar.
Its a truck, and then the fan would have to run ALL the time.. which it does now.. so why move it
Old Oct 24, 2006 | 04:13 PM
  #369
bamachem's Avatar
if the electric fan isn't cutting it, then the stock fan won't touch it.
i'd look closely at the radiator fins and bleed the air out of the system first. second, look at the shroud and make sure that you can get enough air through it at forced induction on the highway.
Old Oct 24, 2006 | 05:10 PM
  #370
mt_goat's Avatar
Andy are you saying the stock fan would be worse?
The radiator is new so the fins are perfect, the AC condensor however has 13 years of bug hits. I've picked it as clean as I could with tweezers and hosed it out.
Yeah maybe I didn't bleed it good enough. I hear if you elevate the front end that helps get the air out but I've never done it that way.
Brian yeah I have a pickup but it has a cap over the bed, so it may as well be a 4runner with respect to air flow in the bed area.
Thanks guys, keep the ideas coming.
Old Oct 24, 2006 | 05:15 PM
  #371
bamachem's Avatar
i think the stock fan would be worse.
right now, i'm thinking that you have air in the system. park it on an incline and see if you can bleed the air out and then top off the coolant system. that thing should be cooling it very well and not having any issues.
Old Oct 24, 2006 | 05:16 PM
  #372
mt_goat's Avatar
You would think so, lots of guys are using the TJM on the newer 4 runners. Here's some better pics of the bumper, I no longer have the bug deflector though:
Old Oct 24, 2006 | 05:19 PM
  #373
mt_goat's Avatar
Ok I'll try that, I really hope that's all it is.
Old Oct 24, 2006 | 05:55 PM
  #374
Bigblock's Avatar
MY 2 cents :hows the rad cap?The more pressure the higher the boiling point.
Old Oct 24, 2006 | 06:15 PM
  #375
04 Rocko Taco's Avatar
Dale, just a crazy idea, I dont think you have the room in the front, but check out the design of a Subaru WRX STi's radiator and intercooler. I think stock the intercooler sits on top of the motor, but all of the tuner guys that run it, run these huge front mount intercoolers, so that they no longer have room for the rad's. They mount the radiators and even the intercoolers at an angle in the front, a V is how they do it most often, but since you don't have an intercooler on that thing...if you were to angle the radiator, could you get it a lttle higher, clear some more of it above the TJM? Could probably get a little more airflow that way, but I know your running low on spare room in the front end...so just an idea... let me know.
~Chris
Old Oct 24, 2006 | 07:24 PM
  #376
89934runr's Avatar
I think your shroud is hurting overall flow at speed- try putting some rubber flaps along the edges, kinda like an air check-valve. My 68 Firebird uses one of these SPAL dual 11" fans, and doesn't have any problems:
note the series of six flappers (3ea fan) along the top and bottom. You can get the flaps seperately from Spal, as a buddy uses them on his shroud kits.
Old Oct 24, 2006 | 07:43 PM
  #377
mt_goat's Avatar
Excellent idea! Thanks
Old Oct 25, 2006 | 01:01 AM
  #378
AH64ID's Avatar
The TJM looks to block maybe a little more air than the ARB. Were those photos before the 1" BL or did you make a custom bracket? Maybe add some louvers on the sides of the winch.
I like what 8993 showed you... could be easy to adapt to your current setup.
Let us know if you get any more fluid in after "burping" it, thou I still dont think its that since it takes less power at highway speed than it does in stop and go, even on 33's.
Old Oct 25, 2006 | 03:55 AM
  #379
mt_goat's Avatar
Yeah those were before my 1" BL but I raised the bumper about 1" too.
Old Oct 25, 2006 | 04:10 AM
  #380
mt_goat's Avatar
I'm not seeing them on their website, are they a special order thing?
I found some blue prints:
http://www.slickcar.com/pdfs/11Fans.pdf
