3.4/1994/g144
Old Jan 5, 2017 | 04:07 AM
88_Red_Runner's Avatar
3.4/1994/g144
Bought this beauty for $500.00.
Limped her back home.
Vaccumed, engine removed, and transmission.
Old Jan 5, 2017 | 12:18 PM
Cut up crossover with bell housing and y-pipe in place.
Spot welded.
Clearance.
Top view.
Factory and modified.
Factory bolted on.
Modified bolted on.
BBQ paint.
I plan on using the factory heat shield too.
Old Jan 5, 2017 | 12:28 PM
I have the complete donor, which is a 1996 T100 automatic. I'm using the auto in this swap. I picked up a floor transmission shifter from a 1997 4Runner. More to follow soon.
Old Jan 5, 2017 | 01:04 PM
Sold my old 4x. SASed 95 Tacoma FJ80 front axle 2002 Tacoma e-locked rear 5.29's, was a 2x, blah blah blah.
Thought you guys might like. I also bumped my 88_ReD_RuNnEr Tired of IFS thread for you guys to check out. Enjoy.
Old Jan 6, 2017 | 06:41 AM
High pressure line 180 degrees.
Return line.
Fuel hose routing.
Old Jan 6, 2017 | 06:44 AM
This engine is for mockup only. I think it has a blown head gasket. It still run, however, I will place it in until I get a new engine or rebuild.
Next up is cross over and Y-pipe.
Old Jan 6, 2017 | 07:11 AM
Fuel lines and cross over with Y-pipe rear view.
Old Jan 9, 2017 | 12:02 PM
arroyobass's Avatar
I appreciate all of these awesome pictures! I am working on my swap right now, and this is helping me quite a bit!
Old Jan 9, 2017 | 04:14 PM
You're welcome. Let me know if there's any thing else you need for pictures or advice.
Old Jan 11, 2017 | 04:40 PM
Vin. For reference.
Vacuum for reference.
Then found this mess under the steering column. 1994 alarm system by homeowner...
Awesome...
Old Jan 31, 2017 | 04:49 PM
JDM engine in place, with 3.0 oil pan and crossover pipe in.
