3.0 to 3.4 swap help
Old Jul 24, 2012 | 07:13 PM
  #41
Racer's Avatar
Finally found another 3.4 motor. Complete with a few extras for $100 bucks. Gettin that friday then start callin all the wrecking yards for a wiring harness. And order all the rebuild stuff and headers for this one.
Old Jul 24, 2012 | 11:54 PM
  #42
Racer's Avatar
Also a couple questions here. Should I bother with headers for this motor and this swap. Is it worth the money vs power. And if I so get them... Any problems that will come up or eliminate during the swaps? Thanks guys.
Old Jul 28, 2012 | 11:10 PM
  #43
Racer's Avatar
I got the 3.4 all torn apart. Goin to machine shop Monday and oredered stage 2 clutch and rebuild kit for it. Need an ecu and harness from a manual. This wiring is scary looking. Even the old stuff. Might be over my head. We wire up our race cars but thats a lot simpler. Guess no on headers even tho got no reply. Also suggestions on intake set up? And I can't use the 3.0 starter with 3.4 clutch flywheel correct? Also the crank positioning sensor and camshaft sensor, should I replace those just for gp so they don't go out anytime soon? Please someone thanks
Old Aug 12, 2012 | 10:41 PM
  #44
Racer's Avatar
Anyone? Can I use my 3.0 starter? Putting the engine in this week
Old Aug 12, 2012 | 11:03 PM
  #45
vasinvictor's Avatar
https://www.yotatech.com/forums/f160...-3-4-a-239228/
If you'd just search, every question you've asked has been answered. Help yourself out! Good luck installing the motor.
Old Aug 13, 2012 | 10:05 PM
  #46
Racer's Avatar
Ok thankyou!
Old Aug 13, 2012 | 10:11 PM
  #47
BadaBoom!'s Avatar
cant wait to see it swapped... i am in a similar situation
Old Aug 13, 2012 | 11:59 PM
  #48
Racer's Avatar
Yes pretty excited. Get all parts back from the machine shop tomorrow,well today. Then put the whole engine together and drop in by Friday. Then I'll start finding specific problems and things I need help with. I got a valve job and cams adjusted, heads and block decked, and just honed for the new pistons.going to be pretty nice. Can I just run custom dual exhaust? Cut the flanges off the crossover and weld pipe to then, route pipe down both sides? Thanks all.
Old Aug 14, 2012 | 12:01 AM
  #49
Racer's Avatar
If my timeline is right and I have this thing running and driving by first of september, it goes in for paint mid sept before winter hits! already did the straight axle swap, hopefully I don't run into any huge problems with this, I'll find out soon.
Old Aug 15, 2012 | 01:21 PM
  #50
Racer's Avatar
Really need a couple quick answers here. I have a 2000 4runner engine, used to be auto. Going into my 1991 manual. Can i use any year harness and ecu, or only 2000? and i can get an auto harness for $120 and ecu for $120 but its also an auto. Can i make these work with my application. Thanks.
Old Aug 21, 2012 | 01:44 PM
  #51
anthony1's Avatar
I'm sure you can still use the auto harness but you'll have to re-pin them.
I re-pin my 96 auto harness to work with the manual ECU.
Old Aug 21, 2012 | 10:50 PM
  #52
Racer's Avatar
Ok great thanks, I found a manual ECM, so just need the auto harness I can get and I'm set for now.
Old Aug 24, 2012 | 10:31 PM
  #53
Racer's Avatar
I have a few more questions. 1. Can I use my 3.0 power steering stuff?
2. Also can I use the 3.0 alternator? Would be best because I replaced it with the higher amp one awhile back. Last is I need to flip my fuel line on the 3.4? Where all the injectors mount? Thanks. Should be my last ones until a bit of wiring. My engine is in. Just bolt it down. Start on battery and airbox relocation, and figure these things out.
Old Aug 25, 2012 | 10:33 AM
  #54
anthony1's Avatar
I used the stuff from 3.4 except the AC compressor.
Most folks flip the fuel lines "before" installing the engine. Anything can be done, I guess...
Old Aug 25, 2012 | 05:07 PM
  #55
Racer's Avatar
Ok thank you very much! Flip the fuel lines on the injector tower? I still don't completely understand sorry, thanks
Old Aug 25, 2012 | 07:32 PM
  #56
anthony1's Avatar
at the end of the fuel rail. There's the one line from the tank, one return back to the tank.
Do a search on this forum on fuel line..
Old Aug 25, 2012 | 09:25 PM
  #57
Racer's Avatar
Ok thanks. Also why can't I use the crossover pipe from 3.4 and just have it drop down the passenger side?
Old Aug 25, 2012 | 09:27 PM
  #58
Have you LOOKED down that side of your truck?
Old Aug 25, 2012 | 10:34 PM
  #59
Racer's Avatar
Yes I have, tight. I just don't have a crossover pipe from the 3.4, was looking into headers for it but don't want to spend all the money on them then have to modify a bunch. So I'll have to look for a stock crossover from 3.4 and switch it. Just having the 3.4 exhaust manifolds is there anything I can do from the flanges down without that cross pipe? Like duals and make my own flanges that connect to the exhaust manifolds?
Old Aug 25, 2012 | 10:38 PM
  #60
Racer's Avatar
Pretty much the last thing to solve and 3.4 is dropped in. I did a COMPLETE rebuild on it. Engine and full rebuild with valve job, decking the block and heads and bore, new pistons, just everything. Just the exhaust left! Need some options!? Thank you guys
