2RZ to 5VZ? What's involved?
I see a lot of threads on dropping a 5vz into older pickups, but what about swapping out a 2rz out of an 01-04 tacoma for a 5vz? The idea sounds simple, but isit?
I believe you'll need to move the motor mounts back a little bit, You'll want the whole engine harness and ECU from the donor and all the acessories (PS PUMP, Alternator...) all that basically the long block because they will not change over.
Theres some more info in this thread
http://ttora.com/forum/showthread.ph...t=motor+mounts
I have not purchased the vehicle yet. I am actively looking for one now. However, I am assuming if my new truck is an automatic, it make sense to get a donor truck that is also automatic.
I was assuming a prerunner model would be an ideal donor because there is no transfercase just like my 2wd pickup. But... If I were to come across a 4wd model, could I still use that? Is the transmission the same between the prerunner, and 4wd model? Just a T-case attached to the 4wd? That is my question... Thanks
All the prerunners Ive ever seen are automatics. They are 2wd but have all the same suspension as a 4wd, so the oil pan would be different, You want to get a oilpan from a straight up 2wd non pre runner pickup. I have one pm me if you end up needing it.
Are you saying the oil pan in the prerunner model is too large, and will be in the way of something on the little truck?
LCE_Performance
Oct 1, 2015 01:03 PM
