2000 Taco 5sp 3.4l into a SAS'ed 1995 PU 5sp 3.0l
Old Jan 20, 2009 | 07:50 PM
  #41
neoworm0's Avatar
Hophead, thanks for the offer. I think we actually met once. I bought something off you or vice versa. I can't remember now. Regardless, it would be good to check out your swap and maybe pick your brain on a couple points at some time.
Old Jan 21, 2009 | 07:55 AM
  #42
aferg's Avatar
Thanks for the "heads-up" Looks like a first class job so far!
And, Yep, I still have the Motorhome. Not thinking about selling though :-P (I have another kid on the way so it looks like it will be my only project truck for quite some time)
Andrew. :-)
Old Jan 21, 2009 | 04:10 PM
  #43
neoworm0's Avatar
Thanks Andrew. Weren't you holding a newborn when I picked up the motor. You've been busy. lol
Well I didn't have time to do much today. Got the old battery tray out though. I Drilled out the spot welds. Toyota bonded a few corners with epoxy or something. I just peeled it off and it came away easily.
Cleaned it up and sprayed some paint on it. I think I am going to put the motor in soon. Then I can mount the airbox and start the wiring.
[IMG][/IMG]
Old Jan 21, 2009 | 04:34 PM
  #44
cadman's Avatar
Your swap is looking clean
Old Jan 21, 2009 | 09:25 PM
  #45
neoworm0's Avatar
Thanks Cadman. Your swap is one of the cleanest I've seen and I'll be copying a few of your ideas. Although without access to a machine shop I'll have to hide some of my fabrications under a little more paint.
Old Jan 22, 2009 | 04:33 PM
  #46
neoworm0's Avatar
Did some detailing today.
Before:
[IMG][/IMG]
After:
[IMG][/IMG]
Mounted the igniter and put the new release bearing in:
[IMG][/IMG]
Put the ORS xover on the motor. Had it ceramic coated first. I think tomorrow she goes in:
[IMG][/IMG]
Old Jan 23, 2009 | 09:03 PM
  #47
neoworm0's Avatar
Today was a good day. Got the motor in the bay. Went a lot easier than I anticipated.
It sure fits in there well. Motor mounts and tranny both line up perfect. I can't believe how much more room there is to work on it compared to the 3.0.
Here are a few pics.
Flywheel and pilot bearing installed. Pilot bearing proved to be a PITA to get out but I managed.
[IMG][/IMG]
New clutch:
[IMG][/IMG]
[IMG][/IMG]
My neighbour Clive helping me drop it in:
[IMG][/IMG]
There she is. It sits pretty high without a body lift. Definitely going to need a hole in the hood. LOL.
[IMG][/IMG]
Old Jan 23, 2009 | 09:15 PM
  #48
yotasavg's Avatar
woot!
Old Jan 24, 2009 | 05:11 AM
  #49
mt_goat's Avatar
Beautiful
Old Jan 24, 2009 | 08:20 AM
  #50
cadman's Avatar
Old Jan 24, 2009 | 06:53 PM
  #51
aferg's Avatar
Nice...
Old Jan 26, 2009 | 01:30 PM
  #52
Wheelingnoob's Avatar
Woooo SWEET!!
I gotta get off my ass and get over there lol.
Jeremy
Old Jan 26, 2009 | 06:51 PM
  #53
Gavman's Avatar
Looks great Axle... if you need help...
Old Jan 26, 2009 | 09:28 PM
  #54
neoworm0's Avatar
Thanks guys. It's working out well. I had to take a couple days off. Life got in the way. I am going to see about getting the airbox mounted tomorrow. Then start hooking up various things.
I'll post up a few pics of how the airbox mounting turns out.
Old Jan 27, 2009 | 06:41 PM
  #55
neoworm0's Avatar
Well I had the day to work on a few things. I got the airbox mounted. I basically copied Cadmans thread with some minor changes. Here's a link to his thread:
https://www.yotatech.com/forums/f160...16/index5.html
I drilled a 3.25" hole for the elbow and then elongated it so that I could put the mounting flange on the inside like they are stock. I was originally just going to mount it to the outside like Cadman but with my airbox location it made more sense to put it inside. I had to make one bracket to help support it.
[IMG][/IMG]
[IMG][/IMG]
Then I made a small "L" bracket to support the tube inside the fender.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I had to cut the top and rear support arms off so I made another support to go underneath. I reused the stock rubber bushings to mount the box to the bracket. It bolts on inside the box.
[IMG][/IMG]
[IMG][/IMG]
The back of the airbox sits just off the sheet metal. So I cut a hole in the back bottom of the box and put one of the stock rubber isolaters in it. Then I just bolted it right to the sheet metal. Worked out perfect.
The metal sleeve is missing in the picture.
[IMG][/IMG]
[IMG][/IMG]
Nice and solid but flexes a bit to allow for engine movement. I compared it to a stock one and it felt about the same.
[IMG][/IMG]
[IMG][/IMG]
Old Jan 27, 2009 | 06:57 PM
  #56
neoworm0's Avatar
With that out of the way I didn't have a lot of time left so I did a couple of little things.
I hooked up the heater hoses. That wasn't fun! Incidently, can someone tell me if I hooked these up right. I couldn't remember which goes where. I think it's right but I wouldn't mind a confirmation. Thanks.
[IMG][/IMG]
[IMG][/IMG]
I think I am going to splice a "T" in there as well, to help bleed the system.
Then I installed the clutch hose bracket. So far the part I am the least impressed with from the ORS kit. I'll probably change this in the future.
[IMG][/IMG]
Cut and modified some bracket for the engine harness and routed it behind the charcoal canister.
[IMG][/IMG]
I hooked the vacuum line up for the brake booster. i almost forgot to put the one way valve back in.
[IMG][/IMG]
Last I mounted the starter and called it quits. I think I'll mount the rad and fuel lines tomorrow, then start thinking about wiring.
Old Jan 27, 2009 | 08:52 PM
  #57
Looks great!
Want a hand Saturday if you are working on it?
Jeremy
Old Jan 27, 2009 | 09:08 PM
  #58
JonnyBoy's Avatar
The heater core hoses look like I did it, with the exception of a couple "T's" I put in for the rear heater.
Old Jan 27, 2009 | 09:26 PM
  #59
neoworm0's Avatar
Not sure what I'll be up to Sat. Jeremy but if I plan on working on the truck I'll let you know. I might go skiing though.
Jonnyboy, thanks.
Old Jan 28, 2009 | 05:36 AM
  #60
cadman's Avatar
Looking good, Axel. Yes, the heater hoses are hooked up correctly. You should be close to firing it up with the progress your making
