1st Gen 4Runner 3.4L Swap
Old Jul 20, 2009 | 07:00 PM
asg1290's Avatar
Well I got a pretty cheap 1988 4Runner 3.0L 5spd in a no start condition. Got it started finally but it's got a nasty knock and doesn't seem worth fixing at this point. I found a rolled 95 Tacoma 3.4L 5spd with about 210k miles on it and am thinking it could be a good donor.
Now 210k seems like a bunch of miles so is it worth it?
If it was worth getting it what stuff would you replace while the motor was out?
Thanks
Alex
Old Jul 20, 2009 | 07:10 PM
Tofer's Avatar
Sponsor
210 isnt too bad... i would replace the timing belt and water pump... but it sould be a good motor. the 3.4 5sp to a 3.0 5sp is easier swap than the more common 3.4 auto to 3.0 5sp... if it was me, i would say go for it... are you going to get the whole truck or are you going to get just the motor? i bought a whole 4runner and parted out everyhting... i ended up getting the motor for about free (i say about cuz it took longer and therefore i had more shop rent than if i just just bought the motor ready to drop in and didnt hvae to part out a truck first)
good luck and keep us posted..
Old Jul 21, 2009 | 09:59 AM
asg1290's Avatar
Yeah if I get the one I talking about here it would be a full truck that just has been rolled. It still runs and drives but it's not really road safe I'll give him a call today and see if I can get a price worked out but he said he would deliver it to wherever I need it to go which is another bonus. I'll keep you all posted.
Old Jul 21, 2009 | 10:01 AM
asg1290's Avatar
Another question I have would be the wiring. I have the FSM for a 1989 4Runner but mine is an 1988. Did they change much between the two years or would my 89 FSM be okay?
Old Jul 27, 2009 | 12:25 PM
asg1290's Avatar
Well got that rolled Taco. It's sitting at my buddies garage as we speak. It had been sitting a while in the PO's backyard but the engine compartment was very clean and it still fired up on the first try and is still "drivable" though it wouldn't be very comfortable. The interior is another story but I already have some offers for parts out of it which will make this cheaper. I'll try and get some pictures up shortly before the swap.
Old Jul 27, 2009 | 01:35 PM
yodathespian87's Avatar
Well seeing as you right here in town feel free to come by and check out my swap. I am not yet done but already did the oil sender swap, oil pan swap, oil pick up. Half way done the wiring. Seeing as you have the entire truck that will come in handy as that is what has stalled me considerably trying to piece together everything. Love to see some pics. Feel free to send me a PM if you have any questions.
Old Jul 28, 2009 | 07:06 AM
asg1290's Avatar
I'll def take you up on that, what part of town you in?
Old Jul 28, 2009 | 01:31 PM
Academy between N. Carefree and Austin Bluffs. There are a bunch of apartment over there. I'm in those.
Old Jul 28, 2009 | 03:44 PM
mutt's Avatar
I might drive down and check it out too if this is an "open" invite. I'm also doing the 3.4 swap on an 88 3.0 4runner. The part kicking my butt right now is the crossover pipe. I'm trying to fab one using the old 3.4 and moving things around a bit but I'm having a hell of a time getting it all lined up because when you're doing it outside the engine bay you're really blind as to whether or not it will clear the firewall/tranny/framerail!!!
Old Jul 28, 2009 | 08:12 PM
RobD's Avatar
When I had mine built, the engine was out of the truck and they had to do it more or less blind while I pulled the 3.0.
Basically, it took two attempts, so I'll try to save you some $$. The first attempt I had, I tried to have them re-use the two flanges that bolt to the engine and the 2-into-1 collector at the other end. When I got the engine back and tried to drop it in, the 2-into-1 collector wouldn't clear the frame rail and firewall. There are guys who have done it, but in my case it wasn't going to work. So, I had to yank the engine out and drag it back to them to fix the crossover.
On attempt number two, I had them build the crossover as tight to the block and where the bellhousing bolts up to as they could, but still allow clearance for the bolts, and get rid of the 2-into-1 collector and just use a standard 3-bolt flange. This second attempt fit beautifully into the engine bay and everything looked like it was made to go in.
Old Jul 29, 2009 | 03:15 AM
UKrunner's Avatar
I ran duals down each side of the block and bellhousing. The passenger side takes a 90 degree turn towards the drivers side right infront of the sway bar. I have a 2 into 1 connector where the original cat was and run the remaining stock 3.0 exhaust.
The best bit, it all cost $91!
Old Jul 29, 2009 | 04:22 AM
Yeah I will be doing the same running duals. I have a friend that works at a exhaust shop and I'm just going to let him do it. Oh and it is a open invite, you are welcome to come by anytime after August 8. By the way I have a thread on here which kinda shows where I am at as of now.
Old Jul 29, 2009 | 08:52 AM
asg1290's Avatar
I'm having my crossover fabbed by Mufflers Plus in Manitou Springs. They come highly recomended by a lot of people in the area.
Old Apr 6, 2010 | 03:33 PM
asg1290's Avatar
Most of the swap is done, I don't have a tach though. I have a nice hole in my hood just need to get something fabbed up now to cover it. The truck drives great so far just need to tidy up the details.
Old Apr 6, 2010 | 06:51 PM
I got a hood scoop from summit racing it looks really good. In the process of bondoing it. There is a guy parting out his Toyota on CL. Same generation that you have. (I think)
Old Apr 6, 2010 | 06:52 PM
Where is the pics?
Old Apr 7, 2010 | 09:51 AM
asg1290's Avatar
Where is the pics?
They are coming shortly, I promise. It was too dark yesterday when I finally got it on the road.
Old Apr 7, 2010 | 04:31 PM
BigBluePile's Avatar
pics please!
Old Apr 7, 2010 | 08:31 PM
asg1290's Avatar
pics please!
Here ya go
Old Apr 7, 2010 | 09:39 PM
dntsdad's Avatar
Sweet! That is my next project. 3.4 into 2nd gen......as soon as I find a good 2nd gen and another 3.4. LOL
