Zaino Question
I'm about to order Z-2,Z-5, and ZFX for my 4Runner. I was wondering if I need to order Z-1 also. This is the first time I'm using Zaino.
thanks, Roy
thanks, Roy
Yes, you should use it before the wax and between coats. It is supposed to enhance the "wet look". I just started using Zanio myself and am very pleased with the results. Bob
Re: Zaino Question
thanks, Roy
thanks, Roy
From what I understand, Z-1 just prepares the paint to bond with subsequent coats of Z-2. As long as your first coat is Z-1, all that remains is the desired number of coats of Z-5 and/or Z-2. Even Z-5 is optional depending on the condition of your paint. Once you learn how little to apply, you probably won't need ZFX, either. Drying time is only a problem for coats that are too thick.
I have one coat of Z-1 and probably six or seven coats of Z-2 on my seven month old truck, but no Z-5 yet.
It all sounds very confusing until you actually do it, but I've been using for over two years and it's the easiest, longest lasting, finish I've ever used.
Re: Zaino
Originally posted by Cebby
Excuse my ignorance, but what is Zaino?
I am all about taking care of my new truck, but man ... that sure does seem like a lot of work.
So basically, since the car is new, I will only really need to hit it up with Z-1 once, and then as many coats of Z-2 as I want?
Are there any other products that you guys suggest or is Zaino the absolute best?
"Best" is something only you can decide. As far as durability, it's right up there.
I reapply just because I want to, not because I need to.One other thing to do before you do any polish application is to clay the finish. Yes, even on brand new paint. It's WELL WORTH the added time. You'll be amazed at the difference it'll make!
To be honest, I really want a good product that will hold up really well against road tar, small stones, salt (in the winter), etc. Is the Zaino more of a "show car polish" than a protectant? I want something that will protect me the best and look nice too.
From what I have read, the Zaino seems to give you that super duper look, but nobody really says much about the protection that it offers.
As far as small stones are concerned, you'd need a bra, Xpel, or something similar for the utmost protection.
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
