relocating Oil Filter 2001?
Old Jun 26, 2002 | 10:51 AM
bsinwa's Avatar
hey! any of you guys / gals moved your OF to a new more accessible location (a la PP kit or other?) Where did you put it that is safe and accessible. I have a 2001 3.4L 4WD.
Thanks for the input!
best! BS
Old Jul 9, 2002 | 04:57 AM
peterbilt's Avatar
I think the most common place is to install the relocation kit in the forward area of the driver's wheel well (3rd gen). I believe they moved the canister inside. Someone installed it on the inside of the wheel well in the engine compartment and was a nice installation but a lot of work. I liked it. I'll look for pics. Gadget has a dual filter setup under the drivers seat area of the chassis. He said it was an awfull lot of work though.
Pete
Old Jul 12, 2002 | 09:13 PM
HBoss's Avatar
I have a '97 and plan to do this mod this fall or next year. I think I'll be relocating mine into the engine compartment though. I don't really like it being in the wheel well myself, but that is certainly a popular choice for many.
Old Jul 31, 2002 | 03:36 PM
Greg's Avatar
:tomcat:
I've decided to switch to Mobil1 and run a really high quality oil filter (K&N or Mobil1) to stretch oil change intervals to 7500 miles rather than screw with the relocation kits.
NWOR has some trick kits though with stainless oil lines and dual filters. If you have to move it look into those.
good luck
Old Aug 1, 2002 | 07:33 AM
Hermes's Avatar
Ok, getting to the oil filter when I couldn't get my front skid plate off was close to impossible. But it really isn't that bad when you take off both skid plates. As it has been suggested, take them off as one unit - much easier. Then no need to relocate I don't feel comfortable putting an oil filter in the wheel well, it seems like you are asking for trouble. Just my $.02
Old Aug 1, 2002 | 10:02 AM
Corey's Avatar
Co-Founder/Administrator
I thought Gadget had put the Amsoil oil filter relocation kit on his rig, but I can't find it on his site.
It may have been another 3rd gen owner who had done this mod.
Old Aug 9, 2002 | 02:27 PM
bsinwa's Avatar
well, changed the filter - thru the driver's side wheelwell. What a pain! Those little clips aren't gonna last long - guess I better stock up on em.... Glad it's only an every 6 month thng but sure wish I could find a nice protected, convenient place to put the filter But then again, I bet getting the relocation plate on there would really be a bitch!
Old Aug 20, 2002 | 07:44 PM
Dandeman's Avatar
Oil Filter relocation kits
Also now using synthetic oil and stretching the oil change interval a bit..
Unless the oil filter relocation kit used stainless braid hoses, or top quality (e.g. aeroquip http://www.aeroquip.com/ ) I would be a little leary of them..
A hose rupture could be bad news.. not only for the engine, but if motor oil ever hit the catalytic converter, almost a guaranteed fire... (probably not likely with the cat on the opposite side, but not a failure I'd want to chance..
Eggslinger
Jun 8, 2019 03:32 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
93toyoguy
Aug 2, 2015 07:41 PM
calderp
Jul 27, 2015 09:58 AM
mengquis
Jul 13, 2015 10:39 AM
