Noisy tailgate
Old Apr 11, 2005 | 09:07 AM
Buck01's Avatar
Unhappy Noisy tailgate
I did a search on this and didn't find anything yet.
I have a 94 Toyota pickup 4x4 22RE, 5spd, 175,000 miles.
My tailgate rattles like crazy. It looks like there should be some kind of plastic clip or something that keeps it from rattiling.
Any ideas?
Thanks
Joel
Old Apr 11, 2005 | 09:10 AM
terryjmatthew's Avatar
Not sure about Yotas, but most trucks have bushings where the tailgate attaches to the bedsides.
Old Apr 11, 2005 | 09:30 AM
89_4runner's Avatar
My 4Runner originally had plastic clips on the side of the tailgate that broke off many years ago. I think the plastic clips are there to keep the metal links from rattling against the tailgate and bed opening. Years ago I placed some adhesive velcro loop strips on the links to take up the gap. Not the prettiest solution, but it got rid of the rattling.
Old Apr 12, 2005 | 09:35 AM
blainelukens's Avatar
my tail gate on my 89 PU rattles a little which is unstopable/ when you open the tail gate there are 2 bolts on the bottom that could be loose, also there are 2 plactic clips that hold the (folding arm-metal part that holds tailgate up when opened) off of the bed to reduce rattleing that is probably what is gone, you could jimmy rig something or just buy new ones at the dealer and it should stop
Old Apr 12, 2005 | 10:33 AM
Buck01's Avatar
Thanks Guy for the suggestions. I thought those clips should either be putting a little tension against the gate or somehow keeping it from rattling. They are of course broken and I would need to get some froma dealer because I am sure they break on all of the trucks.
thanks again.
Old Apr 12, 2005 | 07:11 PM
jscarrozzo's Avatar
mine does the same thing..u arent the only one...93 pickup...noisy only if u have the rear sliding window open. In fact, I think i going to rig somethin up tomorrow.
Old Apr 12, 2005 | 07:24 PM
photoleif's Avatar
can you rattle the gate itself, or is it tight? if it's tight, can you rattle the arms at the sides? if those rattle a lot, get out your ph#1 screwdriver and tighten them as far as they'll go. there's a keyed end to the arm that keeps them from becoming so tight that you can't open or close the gate. padding, as clint said above, is a workable stopgap until you can find a more permanent fix.
Old Apr 12, 2005 | 08:43 PM
89_4runner's Avatar
You could always buy the plastic clips from the dealer, but they will likely break again. Plus, they probably want an arm and a leg for them.
My temporary fix with pads on the links has been working for many years. And, it's pretty cheap. Just my $.02
Maybe you could do something like coat the side links with Plasti Dip?
Old Apr 13, 2005 | 04:33 AM
Buck01's Avatar
Photo..the gate itself rattles. There may be some noise from the links too. I have not looked at them. I will check them out tonight.
894runner I will try some kind of pad or plasti coat on the links first before buying the clips from the dealer.
I was thinking ( I know scary) that if the gate is rattling in the latch maybe I could use the welder and build up the latch hole just a bit so it fit tighter.
what do you think?
Old Apr 13, 2005 | 05:47 AM
89_4runner's Avatar
Buck01,
I don't think I'd use the welder to build up the latch hole. You should play with the latch in the tailgate to see if it is working properly. I think mine has a couple of stops when it rotates around the latch pin. It should work something like the latch on your doors even though it looks different. One latch grabs to keep the tailgate shut, but you will get a little bit of movement. If you push the tailgate harder, the second latch grabs and holds the tailgate tight with the bed. Does that make sense?
Old Apr 14, 2005 | 06:29 PM
Sleeper's Avatar
I used some adhesive backed foam to stop my rattle. Kinda like the kind people use as a buffer between camper shell and bed.
I8URSVT
Mar 2, 2021 06:23 AM
matmattmatthew
10
Feb 9, 2021 04:15 PM
dbollier123
Sep 29, 2015 05:23 PM
punks_is_4x4
Sep 19, 2015 05:52 AM
ac7822
Sep 11, 2015 08:49 AM
