nasty knock
Old Jul 3, 2005 | 08:13 AM
90runnner's Avatar
nasty knock
3.0L making a knock from the top left side(facing truck). ran amsoil flush and the knock wasnt as loud but still there, hydrolic lifter possibly?... any suggestions before i pull off the intake manifold so i can get to the valve cover to check
Old Jul 3, 2005 | 08:53 AM
94x4's Avatar
Guest
Are you sure that it is coming from the "top" on the passenger ["left side(facing truck)"] side? As this is a common occurrence for the bottom driver's side, i.e., rod bearing.
If so, then I would have to say that it is the lifter and it needs to be reshimmed and/or tightened, both of which you can "search" here for info on.
Old Jul 3, 2005 | 11:46 AM
90runnner's Avatar
yeah, im possitive its coming form up there, thanks for the advice
Old Jul 3, 2005 | 06:25 PM
Bigblock's Avatar
they aint no hydraulic lifter in no 3.0!
Old Jul 3, 2005 | 08:19 PM
94x4's Avatar
Guest
Nah, there's not. But if you point in the right direction, they can usually sort it out for themselves, 3yotys.
Old Jul 4, 2005 | 01:52 PM
90runnner's Avatar
you sure there arent hydraulic lifters? when i was trying to figure it out before i came here i was told it could be a collapsed hydraulic lifter...by a friend who happens to be a mechanic at a local toyota dealership
Old Jul 5, 2005 | 10:36 AM
94x4's Avatar
Guest
The valve lifter, or hydraulic lifter (although it's operation is purely mechanical), or even camshaft follower, is basically a little cup that sits atop the valve, with a shim of varying thicknesses on top of it that acts as a spacer for the cam's lobe to ride on.
Normally the lifter itself does'nt "collapse", instead, the shim becomes worn and needs to be replaced with a new one of proper thickness, which is determined with a feeler gauge and some plasti-guage.
It is also common for a spring to have "collapsed" or broken, but your problem is probally just that the shims need to be adjusted, a "scheduled maintenance" item suggested to be performed every 60,000 mis.,
or every 2 yrs., whichever comes first, which will definitely cause a "loud knocking" at the top of your engine.
Just a little clarification to avoid confusion, so ask your "mechanic...friend" about this and let's know what he comes up with.
Old Jul 5, 2005 | 02:37 PM
90runnner's Avatar
alright, thanks alot man
Old Jul 5, 2005 | 02:53 PM
94x4's Avatar
Guest
No prob, and good luck with what you find out.
Reshimming is the easiest and cheapest route, something you can do yourself, whereas a valve job would start to get a bit more involved and costly as it is common practice to do them all if you have to do one... so best wishes.
moparbay
Mar 10, 2023 03:50 PM
some drunk guy
Aug 3, 2021 06:09 PM
Marley2984
Dec 6, 2015 05:19 AM
moparbay
Oct 6, 2015 09:24 AM
ac7822
Sep 11, 2015 08:49 AM
