Jacks
Jacks
How do you guys get your rigs off the ground with anything bigger than 31 inch tires? I've got 31x10.5's and the factory crappy little bottle jack won't even lift a tire off the ground. I don't really want to carry around a 2-ton truck jack around in the back of my 4Runner, what are you guys using?
-Keith
-Keith
Highlift if I absolutely have to, but I hate to get it off of my roofrack, otherwise my 3 ton Larin floor jack. The bottle jack is only good for a boat anchor after you stick thirtyones on your rig IMO. IMO those bottle jacks are scary! But then again maybe im being a
I use a hi-lift but you may not want to carry a 48" long jack in your runner....
On!
Originally posted by BigBadBlue
In?
On!
In?
On!
Yeah, the picture in my avatar is my 4Runner. I have the factory roof-rack and I don't really think I'll be keeping a jack up there. If I get a new jack it will have to be something that won't take up too much of the cargo area.
-Keith
-Keith
Yeah I was wondering the same thing...the only kind of lifting stuff I have now are 4 wheel ramps to raise the entire truck up about 8 inches but with the wheels on the ramps or the wimpy stock jack...NOT CUTTING IT!
Fink
Fink
Yeah, I'm going to see if I can get one of my Dad's bigass 2 1/2 ton jacks for when I'm at home. I still really need something for when I'm on the road so if I were to get a flat tire I wouldn't be screwed.
-Keith
-Keith
Just for on the road I would just make a good base for the factory jack, or just a good block of wood....
Just curious...what jack point are you all using w/ the bottle jack that it doesn't reach?
If you lift off the a-arm in the front, and the axle in the rear, it should work fine for 31's.
Jim
Jim
Jim
Jim
The Hi-Lift should be a trail tool used on sliders.
I use a regular 12 ton bottle jack on the rear axle or front crossmember and it is fine with 33's.
My jackstands to reach the frame are leaving a lot to be desired.
I bought a hydraulic floor jack that is very compact from Harbor Frieght Tools. $20. I think the tie down in the back will be plenty to keep it in place.
I plan to take it with me on trips since the stock jack is useless.
I've had to use my stock jack and I'm running stock 31s, 265?. I just put it where the manual said to and was able to change out my passenger rear tire no problem.
I wanted to take off my wheels and then re-torque my them to factory spec and found out today that my bottle jack is useless. I guess when I am on the road I either need some wood to elevate the bottle-jack or just get a high-lift.
I bought a 3-ton jack from Harbor Freight ($59) and it did the trick with no problems.
a cheap way to go is get the SUV jack at sears. i got mine for like $30. they lift plenty high enough for my 4" lift and 33s
May-39
Sep 6, 2015 01:05 PM
nickbeauregard
12
Aug 7, 2015 06:04 AM
