Jacks
Old Jan 18, 2004 | 01:49 PM
breakerfalls's Avatar
Jacks
How do you guys get your rigs off the ground with anything bigger than 31 inch tires? I've got 31x10.5's and the factory crappy little bottle jack won't even lift a tire off the ground. I don't really want to carry around a 2-ton truck jack around in the back of my 4Runner, what are you guys using?
-Keith
Old Jan 18, 2004 | 01:54 PM
Yoter's Avatar
Guest
Highlift if I absolutely have to, but I hate to get it off of my roofrack, otherwise my 3 ton Larin floor jack. The bottle jack is only good for a boat anchor after you stick thirtyones on your rig IMO. IMO those bottle jacks are scary! But then again maybe im being a
Old Jan 18, 2004 | 01:56 PM
Cool
I use a hi-lift but you may not want to carry a 48" long jack in your runner....
Old Jan 18, 2004 | 01:58 PM
Yoter's Avatar
Guest
In? On!
Old Jan 18, 2004 | 02:14 PM
Originally posted by BigBadBlue
In? On!
If his pic is his rig then I don't think he has a roofrack so it would be in....
Old Jan 18, 2004 | 03:31 PM
Yeah, the picture in my avatar is my 4Runner. I have the factory roof-rack and I don't really think I'll be keeping a jack up there. If I get a new jack it will have to be something that won't take up too much of the cargo area.
-Keith
Old Jan 18, 2004 | 04:29 PM
Fink's Avatar
Yeah I was wondering the same thing...the only kind of lifting stuff I have now are 4 wheel ramps to raise the entire truck up about 8 inches but with the wheels on the ramps or the wimpy stock jack...NOT CUTTING IT!
Fink
Old Jan 18, 2004 | 05:22 PM
Yeah, I'm going to see if I can get one of my Dad's bigass 2 1/2 ton jacks for when I'm at home. I still really need something for when I'm on the road so if I were to get a flat tire I wouldn't be screwed.
-Keith
Old Jan 18, 2004 | 07:18 PM
Cool
Just for on the road I would just make a good base for the factory jack, or just a good block of wood....
Old Jan 20, 2004 | 05:52 AM
cruizin01's Avatar
Heres what I carry around in the back of my tercel. Makes spare tire swaps real quick.
Jack
Its even on sale
Old Jan 20, 2004 | 06:14 AM
jalaber's Avatar
Might need to carry wood blocks to raise the factory jack up.
Old Jan 24, 2004 | 09:09 AM
jruz's Avatar
Guest
Just curious...what jack point are you all using w/ the bottle jack that it doesn't reach?
If you lift off the a-arm in the front, and the axle in the rear, it should work fine for 31's.
Jim
Old Jan 25, 2004 | 12:52 AM
Robinhood150's Avatar
Jim
That's exactly what I was thinking. I always lift from the a-arms or the rear axle. The hi-lift can be dangerous, it's bulky and must be bolted to the floor if carried inside, takes a lot of effort to use, plus you have to have armor to use it. I never use the hilift unless I have to.
Old Jan 25, 2004 | 12:40 PM
Flygtenstein's Avatar
The Hi-Lift should be a trail tool used on sliders.
I use a regular 12 ton bottle jack on the rear axle or front crossmember and it is fine with 33's.
My jackstands to reach the frame are leaving a lot to be desired.
Old Jan 25, 2004 | 12:52 PM
FirstToy's Avatar
I bought a hydraulic floor jack that is very compact from Harbor Frieght Tools. $20. I think the tie down in the back will be plenty to keep it in place.
I plan to take it with me on trips since the stock jack is useless.
Old Jan 25, 2004 | 10:30 PM
Darx's Avatar
I've had to use my stock jack and I'm running stock 31s, 265?. I just put it where the manual said to and was able to change out my passenger rear tire no problem.
Old Jan 25, 2004 | 10:53 PM
midiwall's Avatar
I have the same issue with my truck. I ended up doing this with my Hi-Lift:
(click for a larger pic)
Old Jan 27, 2004 | 12:29 PM
ts1's Avatar
ts1
I wanted to take off my wheels and then re-torque my them to factory spec and found out today that my bottle jack is useless. I guess when I am on the road I either need some wood to elevate the bottle-jack or just get a high-lift.
I bought a 3-ton jack from Harbor Freight ($59) and it did the trick with no problems.
Old Feb 2, 2004 | 11:42 AM
3.4v6's Avatar
i got a nice 3 ton floor jack at costco
Old Feb 9, 2004 | 09:35 PM
jsrusse11's Avatar
a cheap way to go is get the SUV jack at sears. i got mine for like $30. they lift plenty high enough for my 4" lift and 33s
BK2TFUTURE
Oct 11, 2015 08:42 PM
May-39
Sep 6, 2015 01:05 PM
shisha1999
Aug 14, 2015 01:33 AM
nickbeauregard
12
Aug 7, 2015 06:04 AM
