Front rotor installation
I'm going to get some new front rotors from NWOR. My question is, is it hard to change the front rotors. I can do most things, brake pads, belts, fluid changes, all that kind of stuff. If it isn't too hard, what tools will I need? Any info will help.
Use a torque wrench on them, be gentle, and make sure you have the big socket for the bearing nuts. I assume you will repack the bearings too. Check out those links sherri posted. Lots of help.
Originally posted by Toby1
Might also want to check the front axle seals and make sure you're not leaking grease.
Thanks for all the info. I'll probably be changing them within the next month.
If things get confusing then i'll be back
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
