Check Engine light!
I just installed a Gibson side swept cat back exhaust, on my 00 taco Prerunner V6, and now the Check engine light comes on. Can anyone help me with this problem? Thanks in advance!
you might need to find a shop that can read the trouble codes off your rig...........i think some places will do it for free or almost no money (unless you have an OBD II reader , then you can do it for free yourself)
do you have a k&n air filter on it by chance, i had a friend whoi had a k&n air filter and installed a flowmaster exhaust, and his check engine light came on, turned out to be the mass air flow sensor was having a problem with all the air. had to replace the maf, hope this helps.
mas that is (mass airflow sensor) :pat:
Thanks for your guys help.
The dang light came back on this morning!I will have to get the code read for sure now......argh!
Yep that is what it is. I have a buddy that used his OBD II scan to find the problem and it 's the sensor right after the catalytic converter. There is no voltage going thru it and it is causing the engine to run lean. It's great to have knowledge of the problem before i take it to the dealership. The warranty should cover it.
Jun 1, 2021 01:51 PM
