Brake warning light on faintly
Old Feb 9, 2003 | 10:02 AM
mark from uk's Avatar
Has anyone come across this befor,
on the dash some times the warning light comes on with a faint glow i might just be imagining it but when it is on like that i feel like the brakes are binding , if i stomp the pedal a few times the light goes on full and then off again , i have checked the fluid level and that is ok, also it is not like that all the time , could it be the pad warning sensors getting wet? any advice any one?
Old Feb 9, 2003 | 07:55 PM
Shane's Avatar
Re: Brake warning light on faintly
*scratches head in total confusion* The what? No such thing...
Check the sensor on the reservior cap and it's wiring, might be going bad. Also check your e-brake's switch and wiring as well.
Old Feb 10, 2003 | 01:16 PM
bldavis11's Avatar
A few months ago my "brake" dummy light also came on and stays faintly illuminated. When I apply the parking brake, it becomes fully illuminated. No change in brightness when I apply brakes though.
How exactly do I check the wiring for the parking brake? I figured some relay had gone kerplunk on me.
-Davis
'90 SR5 V6
Old Feb 10, 2003 | 03:34 PM
Eighty7ToyTruck's Avatar
shane, actually there are such things as pad warning sensors...
and some of them, believe it or not are electronic, they use contacts in the pad that connect through the caliper bracket etc...
bld... the sensor in your master cylinder could be going bad... or your parking brake sensor could be shorting or opening...causing the light to get brighter when you stomp the brakes because it would completely open or short the circuit.... good luck
Old Feb 10, 2003 | 04:37 PM
Shane's Avatar
let me rephrase... no such thing in a '90 4runner.
To check the wiring get yourself a factory service manual and a DVM.
Old Feb 11, 2003 | 11:19 AM
bldavis11's Avatar
Thanks for the info Shane. The brake light does not increase intensity when the brake pedal is depressed. It only brightens up when the parking brake is applied.
-Ben
Old Feb 11, 2003 | 05:29 PM
95_4X4Runner's Avatar
I know this sounds hard to believe, but in other older Toyotas, the brake light can illuminate when there's issues with the alternator/voltage regulator.
Old Feb 11, 2003 | 05:35 PM
Shane's Avatar
The charge light will also come on at the same time when this happens.
Old Feb 12, 2003 | 02:17 PM
I think that the first think i will have to do is bleed the brake lines, I seem to remeber from another car i had that they have to be done in a certain order , is this true for the 4runner and any ideas if it would be opposite for a right hander?
Old Feb 15, 2003 | 09:02 AM
Travis's Avatar
Try unplugging the sensor on the resevoir cap. Sometimes the float sensor goes bad.
Does your braking feel odd like spongy or delayed? Your lines could be contaminated.
Old Feb 15, 2003 | 01:46 PM
i think that it might be the fluid so as soon as i get a few clear mins i will have to swap it out
Old Feb 16, 2003 | 01:49 PM
bldavis11's Avatar
I replaced the p-brake switch. Lemme tell you what a pain that was! No avail. Any ideas now? As a recap, the light stays on dimmly all the time, and only becomes fully illuminated when the parking brake is applied.
-ben
Old Feb 18, 2003 | 04:13 PM
Travis's Avatar
As I mentioned before, try unplugging the cable from the reservoir cap. I had the same problem years ago.
fountain
Dec 31, 2015 06:08 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Odin
Jul 15, 2015 09:28 PM
Johntom240
7
Jul 13, 2015 12:18 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
