Old Apr 7, 2016, 11:42 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Brake Guides
Print Wikipost
Brake Light
Old Jan 24, 2003 | 10:25 AM
titan1's Avatar
Question Brake Light
MY BRAKE LIGHT STAYS ON ALL THE TIME. IS THERE ANYONE WHO MIGHT KNOW WHAT THE PROBLEM SEEMS TO BE. I HAVE HAD THE BRAKES CHECKED AND THERE SEEMS TO BE NO PROBLEM. DRIVING ME CRAZY
Old Jan 24, 2003 | 04:38 PM
Cebby's Avatar
Switch
Check the brake light switch attached to the brake pedal arm. Sounds like it's stuck. Pulll the fuse when you aren't driving so it doesn't drain your battery while parked (if that wasn't the problem). Don't forget to put it back in though...
Old Jan 25, 2003 | 02:20 PM
rpeAMP's Avatar
Check to see that you're not low on brake fluid, even in the slightest.
Old Jan 30, 2003 | 07:01 AM
Travis's Avatar
I had the same problem. Sucks because you can't use cruise control when the light is on.
Turned out that the brake fluid level sensor was broken. Toyotas have a float style sensor attached to the rubber brake fluid cap on the reservoir. Over time this sensor wears out and can fail causing your warning light to come on making you think that it is your parking brake.
I just unplugged the thing at the cap. I check my fluids at every fill up to make sure the level hasn't changed.
Old Feb 6, 2003 | 07:19 AM
flobadon's Avatar
Had this problem in my '89 p/u, but one day I was poking around my fusebox and the problem magically disappeared.
Old Feb 11, 2003 | 06:29 PM
L33T35T 4Runner's Avatar
so THATS why my brake light turns on periodicly? it seems to do it during heavy acceleration... hmm.. it is getting lower because my brakes are about done.... i better fill that thing up
ashersullivan88yota
Jan 18, 2022 05:37 PM
fountain
Dec 31, 2015 06:08 AM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
