22R dead?
Old Sep 24, 2004 | 06:43 AM
Joffk's Avatar
22R dead?
Hey folks,
First post here. I have a '90 p/u w/ 22R engine with a carb and it died on me at a stop light the other day. Here's what I found yesterday:
The starter turns the engine, but the engine doesn't even try to start.
The distributor arm spins when the starter is turning.
I have spark.
I dumped gas in the carb but it still wouldn't start.
I have gas in the tank.
When I pulled the spark plug, it was bone dry. It didn't even smell like fuel.
The engine seems real "loose", i.e., it seems to spin fairly easily.
It doesn't seem like I'm getting any compression.
The oil didn't show any signs of contamination.
The radiator was low on coolant, but not bone dry.
The air filter was clean.
Okay, so my questions are:
Could it be my timing chain slipped or the guide on it broke?
Did I blow a head gasket?
Is the engine dead and should I just move on?
Any help in this matter is appreciated.
I apologize if I'm repeating something that's been beat to death before. I did search the forum before I posted.
Thanks,
Jøff
Old Sep 24, 2004 | 07:38 PM
I dont know if the 22r has a chain, but if it has a belt, i would definetly look at that.
Old Sep 25, 2004 | 02:47 AM
Tacoma Dude's Avatar
it's a chain...
Old Sep 25, 2004 | 05:03 AM
bbagwell's Avatar
Check the fuel pump.
Old Sep 25, 2004 | 10:22 AM
AgRunner06's Avatar
Compression test.
Old Sep 25, 2004 | 11:19 AM
superjoe83's Avatar
i would bet that the driver side guide did its usual thing and broke off, then you chain slacked up and jumped a few teeth, the fact that your rotor is still spinning means that the chain didn't break, so your valve timing and ignition timing are off, that is why you have little compression and it wont start because of that, and since the 22r/re's are interference engines, you may have bent some valves and/or broke some rocker arms off
Old May 27, 2005 | 11:59 AM
jimbo74's Avatar
the cam on my 85 22r jumped 3 teeth.... i set it back to 0 and all was better
Old May 27, 2005 | 05:56 PM
kyle_22r's Avatar
test the compression. even if the timing chain jumped you *should* be able to at least get it to pop a couple times.
if it was instantaneous you might've seriously blown a head gasket...
buckz6319
Aug 5, 2017 03:50 AM
Chicken12
Oct 14, 2015 03:54 PM
Obmi
Oct 4, 2015 11:30 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
